3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
music lights idea
Well I've been working on this project for a while now and the design has changed many times. I have also asked several questions based on the ideas. My latest idea is to make 3 different sets of lights flash to music using the 3 outputs of a 5.1 system on a computer. I know this may sound confusing but what I mean is the orange, black and green outputs which control the rear, front and center/subwoofer of a 5.1 surround system. Do you think this could work? If so then I suppose I would use just the right channel of each and possibly the ground connection (not sure whether I need it). Also if using transistors to make an electronic switch turning the lights on and off, would I need amplifiers? I only have 1 at the moment and even if I could get more they would almost certainly be different. If you know the answer to these questions please help and even I am successful the I will create an instructable on this. One more thing: Does anyone know whether the center of the center/sub connection is the tip or middle of the jack? Thanks, Jim
7 comments
Jul 26, 2009. 8:59 AMguyfrom7up says:
I think u could do it with just a diode, resistor, and darlington pair. But I suggest mosfet (you want to effect the audio to the speakers as little as possible) but I totally forget what's the voltage range from an amplifier, do you have an oscilloscope?
Aug 20, 2010. 6:03 AMArduino Guy says:
you do not need an oscilloscope, use winscope or oscilloscope4 there windows compatible for sure, i do not know about mac. http://www.zen22142.zen.co.uk/Prac/winscope.htm i couldn't find Oscilloscope4 but i do have it installed on my computer. Note: a the sound card of a computer will fry if the signal is above 2v you can use a hv probe stick to make 10v into 0.1v and 100v to 1v.
Jul 26, 2009. 9:00 AMguyfrom7up says:
oh, and i didn't mean to say "u" :P, i meant to say "you." too much skype chat too much online games too much txting
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
