my newest project, should be posted before the end of winter break.
well, here is a small look at my newest project. should be posted in around a weak(probably less) i was going to post it on december 24, but mepains posting his thing... anyway, here is a picture of it. one good thing about it is that it uses no cut pieces, and only a little tape. but there is one really rare piece that i can't reveal yet, but i will say that it is probably the best knex thing i have ever made.
Picture of my newest project, should be posted before the end of winter break.
1-10 of 113Next »
jollex8 years ago
Just saying, I think you should wait a bit before you post it, because right now everyone's focusing on the K'nexsayer. So just wait until that dies down a little.
That will take a LONG, LONG time.
Yep.
Its not so hot here on instructables...
What is so great about it? Isn't it just EB's Revolver with a pump and a butt-load of extra pieces? Just because you make something big it's all of a sudden the greatest thing in the world when it would be more impressive if you made it as compact as possible and then that's just what they do. They pull off an Apple and make countless smaller versions of a large weapon so that they just seem like they're the best builder ever for doing what they should have done in the first place over a long period of time. ...no offense IaC.
Try posting your comment on KI. I want to see what happens.
No, not really.
Trigger system is completely different. Mepain's is contained inside the body as opposed to being outside (EB's is on the right side of the gun) in addition to being completely different systems.
Same with the cylinder rotation system. EB's is not automatic, you have to pull back a lock, then manually rotate the cylinder, where as with the Knexsayer, all you have to do is pull the pump. You can even do that after you have pulled the pump once.
The cylinders and firing systems are also different. EB's ram actually goes into the cylinder as opposed to Mepain's, which has a white rod attached to the back of the cylinder in such a way so that it is sticking out of the back without actually being able to fall out. Notice how EB's only has one clip between the ammo clip and where the ram is while Mepain's has three.
Mepain's also has more power and better range due to it's capacity to fire any size rod you want, not just rods smaller than a blue rod.
Do your research before you flame.
lol big mean productive comment of doom!!
Yes, YES! FEEL MY WORDY WRATH!
aggreed!
No. It is the best Knex gun made thus far.
1-10 of 113Next »
