need help for nrf24l01+
Well i am using rf24 module for a project since i am new to it i am having some difficulties to send the data. Actually i am doing a remote consisting of a geeetech voice module + nrf24 + arduino nano. It must communicate with a hub which comprises of arduino uno + rf24 + relays. I have tested the voice module and the data is read as serial command. see the code for a simple example without rf24 below.
For my project i need to make the transmitter read the serial command of the voice module and send it to the receiver side. In the receiver side it will activate relay with a switch case section. I would appreciate if anyone could help me out and suggest me how to send the command of the geeetech voice module via rf24.
//code for simple test between voice module and nano
int led1 = 2;
int led2 = 3;
byte com = 0;
void setup()
{ Serial.begin(9600);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
delay(2000);
Serial.write(0xAA);
Serial.write(0x37);
delay(1000);
Serial.write(0xAA);
Serial.write(0x21); }
void loop()
{ while(Serial.available())
{ com = Serial.read();
switch(com)
{ case 0x11:
digitalWrite (led1, HIGH); //turn red on
break;
case 0x12:
digitalWrite (led2, HIGH); // turn yellow on
break;
case 0x13:
digitalWrite (led1, LOW); // turn red off
break;
case 0x14:
digitalWrite (led2, LOW); // turn yellow off
break;
case 0x15:
digitalWrite (led2, LOW); // turn both off break;
Picture of need help for nrf24l01+
