3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
need help on 555 110v timer.
hey guys w up? i`m asking for help, i`m trying to develop (i have one, similar) a 110 v timer based on the 555 (or any other) i have seen many timers on the web but they run on 9v batt and i do not have room for the transformer , can u help me ??? all (just nothing) all i need is the electronic diagram . i need the timer to work on 110v and run two different cycles a: 90 seconds b: 180 seconds and cut the power. (untill you press the push button again) i have an electric diagram. tx so much. if you need help w something (i`ll try to help you if i can) even if you can`t help me ..ask e have nothing to loose.
5 comments
Sep 20, 2008. 8:17 PMdad45 says:
hey your request got me to sign up. Looks like you last check on it in Aug so maybe I'm too late. I can't tell if you have built many electronic circuits before so if I suggest something basic don't take it the wrong way. First off - 110v (assume the main house power) can be dangerous - fire, shock etc. the 555 circuit will need to run on a small dc voltage, get a datasheet on it if you have not already. suggest using a small battery for the 555 part and a relay to open and close the heavy power. Also, I bought a device (think it was $15-20) to remotely control the outside lights. It wireless controls any 110 device. It's made by dimang. hope this helps
Aug 9, 2008. 11:46 AMDanielro10 says:
iam wanting to know how a 555 timer works, because i want to change the frequncey on my simple indution heater, how would i set that up?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
