need help with 2 cycle motor
11
comments
Add Comment
. Remove the plug, re-attach the high tension wire, ground the threads on the plug to the engine block (will probably require something to hold it in place), and yank the cord.
. If you have a good spark, I'd next check the carburetion system.
. If nothing happened on the first two pulls, it would appear that your magneto (most lawnmower/weed-eater motors have magnetos) is not working properly. It should have bit you quite hard on each revolution.
Fuel problem probably. If taking it apart and cleaning it once worked -try it again on just the fuel system. You might have knocked the float system out a bit for example.
L
Flooded perhaps?
OK, take the plug out, hold the threaded bit on the block and turn-over - spark or electric-shock to yourself?
L
Well that bit works so far. You can diagnose from spark plugs, does this help at all?
http://www.spark-plugs.co.uk/pages/technical/diagnosis.htm
L
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
