portable phone speaker/mic
ok, so I have a portable phone and would like to create some sort of hands-free speaker/mic for it. I'm not sure how to go about doing it and I'm not very internal-electronic-savvy (i.e. chipsets, soldering etc). Ideally, I would assume it should be connectible via the 2.5mm headphone jack. I have an old 2.5mm headset. It's got an ear bud and flexible arm microphone and connects via 2.5mm jack. I should also have some old computer speakers lying around somewhere. I assume that's all I should need. I would like the microphone to be part of the device and be functional, but not sure if it will pick up my voice from a far distance. I'm not too concerned about looks/style, but would be a nice addition. Functionality is my first concern right now, although I do have a few old Fossil watch containers that I could put the speaker(s) in and some sort of dock or rest for the portable phone would be nice as well. If soldering is involved, I will need very detailed instructions. Thanks again! I hope someone can help me. If someone knows of a fairly inexpensive product, I would be willing to buy (since I'm not very soldering-savvy as I said above), but I think this would be an interesting project to build.
1-10 of 18Next »
atomicrabbit (author) 10 years ago
ok i got it working. I had to solder the 2 coloured wires to + and the 2 copper wires to -. Problem is, the speaker is super low, I had to pump up the volume on my stereo to almost max just to get it to play low on the speaker. How would I go about "amplifying" the signal?
A simple audio amp: [http://www.redcircuits.com//Page38.htm Here is one using transistors]
and [http://www.redcircuits.com//Page1.htm Here's one using an Op Amp (operation amp)]
atomicrabbit (author)  Goodhart10 years ago
haha that is absolute gibberish to me haha. I assume I can basically solder the wire with the 2.5mm jack to an old set of pc speakers that have an amplifier, right? Either way, can you explain those diagrams that you linked to. How would I go about making one of the things in those links? Just out of curiosity.
Hmm, maybe getting one of those cheap "hearing aid boxes" that sell for $5-$14 and just using that as an amp, would do for simplicity's sake. :-)
hearing aid amp?? where can I get one?
Those things they advertise on TV for helping the hearing impaired. They are more then worthless for what they advertise them for (they pick up every movement and rustling of the clothes etc,) but they are great little pre-made GP amps.
Here is one of the more fancy ones (but they come in plain box types too for as low as $5 or so: cheap amp link
well, i took the cap off the earbud and this is how the inside of it looks. So would I simply twist attach the copper wire to the speaker's copper wire
Hmm, if the impedance is the same.....otherwise you may need to either match it, or amplify it.
this is all alien speak to me. Can you clarify what you said. What is impedence and how would I match it or amplify it??
Defining impedance then will only make is worse.
In a nutshell it is a measure of the total opposition to current flow in an alternating current circuit, made up of two components, resistance and reactance, and usually represented in complex notation as Z = R + iX, where R is the ohmic resistance and X is the reactance. Normally a speaker will have an approximation of the impedance in ohms written on the back.
If your output has, say 4 ohms impedance and your speaker 16, your are not likely to hear very much from the speaker or maybe some distortion.
I have a bit of the "theory" under my belt, but I am not overly experienced into the nuts n volts & hows of matching impedances.
1-10 of 18Next »
