3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
power supply voltage reduction 9v input to two 3v outputs
Hello all ! I'm new to instructables and I’ve found some cool and helpful information for my projects. I need a bit of help designing a power supply voltage reduction device. One that accepts 9v input and output into two 3v 5mA outputs. I want to replace the batteries in a/b Boss selector with a more reliable source of power.
7 comments
Dec 1, 2007. 8:58 PMguyfrom7up says:
wait, why do you want a more "relaible source", two AA's would last way way way longer than 1 9volt battery.
lets say a 9 volt battery has a life of 500mA, 9 x 500mA= 3500wh
lets say a AA has a life of 2000mah, 1.5x2000= 3000wh
so it may appear that a 9volt has more energy but also take this into consideration:
1) a 9volt takes up the same amount of space as 2 AA's, so it's more like 6000wh.
2) the buck circuit for a 9 volt takes up extra space and is complex, or a linear regulator which is simple grossly reduces the battery life.
Dec 2, 2007. 2:38 AMw00ty32 says:
is wh watt hours?
Dec 2, 2007. 6:47 AMguyfrom7up says:
yeppers
Dec 1, 2007. 10:00 PMGoodhart says:
With a voltage divider, you would end up with a net loss and about 3.5 v on each side.
Nov 30, 2007. 12:48 PMguyfrom7up says:
does it have to be exactly 3 volts? You could convert it down extremeley easy to 3.3 volts using a linear regulator
Dec 1, 2007. 8:48 PMguyfrom7up says:
well generally AA's when brand new prouce 1.7 volts, so that would be 3.4 volts, which I think would be fine, I'll draw you up a schematic really quick
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
