3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
re NASA's Anti Nausea glasses DIYable? I need help because I can't ride in cars without being sick.
I saw a show on the science channel about how NASA is using stroboscopic glasses to reduce the incredible nausea that astronauts get. This is really interesting to me because I have Graves Disease, and the worst symptom is chronic nausea. Right now, it hits randomly when I am in vehicles. Yesterday I had to take a three hour car drive, and white knuckled it the whole way home, trying not to be sick.
I have a few links to a paper about the glasses, and to the patent that explains how they work.
http://www.docstoc.com/docs/2982780/STROBOSCOPIC-VISION-AS-A-TREATMENT-FOR-SPACE-MOTION-SICKNESS-Millard
http://www.patentstorm.us/patents/6932090/description.html
I follow directions really well, and could put it together if someone could tell me what I needed, and how. My electronics experience is limited to a few LED throwies. (I've got a Make: electronics kit I keep meaning to play with, but haven't yet.) I'm not scared of soldering circuits. I'm just not sure how to put them in order, or read the schematics.
I wouldn't even consider this if I wasn't just desperate to be able to be in a motor vehicle without tossing my cookies after an hour. Long trips are agonizing with the nausea, and if this helps, I'd wear it no matter what it looks like in every vehicle I have to be on.
I really want to do this with my own two hands because then if it breaks I can fix it, or adjust it as needed. Plus, it would be just damn cool to build it. I don't know if that's possible, though, because I'm not sure what I am looking at needing to do to make this.
Any opinions would be greatly appreciated.
24 comments
Feb 4, 2011. 10:41 AMvedhz says:
ah.. This is exactly what I was looking for. Good News!!. http://rd3.ca
Feb 17, 2010. 5:40 PMZaphod Beeblebrox says:
i used to get bad headaches EVERY TIME i went in a car,for me it was the window movement and the stillness feeling in the car that was messing with my head.i just don't look out the windows and i'm fine now.wether this would work for you or not i don't know just an idea
hope you figure something out  :-)
Feb 18, 2010. 1:15 PMZaphod Beeblebrox says:
you're welcome hope you find something that works!
Feb 8, 2010. 7:13 PMGoodhart says:
Some "other" meds that work (OTC)
Over the counter medication (usually causes some drowsiness) - to be taken 1-2 hours before boarding. The most recommended are pills with the active ingredient meclizine (less-drowsy Dramamine, Bonine, Antivert), then pills with the active ingredient Dimenhydrinate (Dramamine regular). Marezine (cyclizine) and Stugeron (cinnarizine) seem to be less sleep inducing than all of the above. Other popular antihistamines (Benadryl - diphenhydramine based) also work for some people. (Money saving tip: ask your pharmacist for the generic version of the medication you wish to take.)
Feb 9, 2010. 10:54 AMGoodhart says:
YW, it was just a suggestion, in the event you have difficulties making, obtaining, or getting relief from the glasses :-)
Feb 8, 2010. 12:47 PMKiteman says:
Have you tried anti-nausea wrist bands?
Soft wristbands, like narrow sweatbands, but with a plastic button that presses against an accupressure point.
They don't work for me, but they did relieve Kitewife's morning sickness.
(Randomly googled example)
Be careful, because the first link says that the system works at 4-8Hz, which is the frequency most likely to trigger photo-sensitive epilepsy.
Feb 8, 2010. 1:46 PMKiteman says:
Are you driving?  Goggles like this may be illegal in the US.
Here's a thought - you can get solar-powered key-rings that blink opaque/clear.
Two of those, battery-powered, could be the source of your lenses....?
Feb 8, 2010. 3:37 PMKiteman says:
If you're finding the ones that say stuff like "I (heart) NY", blinking on and off, those are what I mean - there's an LCD screen over a message, "blinking" opaque-clear-opaque.
Feb 8, 2010. 2:46 PMcaitlinsdad says:
ttp://www.maximumpc.com/article/features/everything_you_need_know_about_nvidia’s_3d_goggle_gamble
Maybe the 3D shutter glasses may give you some ideas but you'll have to travel with a laptop next to you.
Maybe if you rig up two of those keychain photoframes in a pair of goggles and rig it up to flash at the right speed.  Or take the 1.5 inch LCDs out and use them as clear lenses to shutter out the natural light.  Good luck.
Feb 8, 2010. 9:49 PMcaitlinsdad says:
Feb 9, 2010. 8:42 AMcaitlinsdad says:
www.instructables.com/id/deul_blinking_LED/
You would need to research using an arduino microprocessor setup to easily program and vary the speed.
Feb 4, 2011. 12:25 PMsteveastrouk says:
Its MUCH easier to experiment with frequency and duty cycle with an Arduino chip - we just ran up a project at work with one.
Feb 9, 2010. 10:06 AMcaitlinsdad says:
Sorry, I am not an electronics whiz, hopefully others will answer. An arduino can control the duration of an LED on and the off period so you can make it flash morse-code like if needed.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
