reducing current on a power supply
So I am trying to reduce the on the current power supply I have from an old router. The out put is 12v DC 800mA (.8A). I want to use it to run a man 12v .3A
I just wanted to make sure I did my math right and to make sure I didnt miss anything.
Ohms Law
I = V/R
R= V/I V = 12 I = .8
12/.8 = 15 ohms resistance in theroy
_
Current on the fan is .3 A, I am assuming that is the max. So desired current is .25
I = .25 V = 12 R is current resistance, X is additional resistance Q=(R+X)
I = V/Q
Q= V/I
R+X = V/I
X = (V/I) - R V = 12 I = .25 R = 15
(12/.25) - 15 = 33 ohm resistance needed
So I would need a minimum of 33 ohm resistor. Am I correct?
Sorry for the explicitness of the math, its been drilled into me to show every step.
lemonie8 years ago
If it's a 12V fan it will be fine, you don't need to do any maths or add any resistors.
(If it's not a 12V fan, tell us what voltage it was designed for?)
L
