3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
selective room heating?
I just turned on the heat before going into my room to go to bed. My roommate and I are in about one fourth of the whole house (and will be for about six hours), yet every room is being heated. This seems like a huge efficiency problem. Are there commercial systems out there that can heat selective rooms? If not, are there ways of making such a system? Can I just tape cardboard over the vents?
20 comments
Dec 9, 2008. 4:56 PMGoodhart says:
Baseboard electric or baseboard radiator heating systems are normally wired separately for each room, so one can heat certain "zones" being occupied, rather then the whole house.
Dec 10, 2008. 12:04 PMGoodhart says:
Occram's Razor !!!!
Dec 11, 2008. 12:44 PMGoodhart says:
Electrical floorboard heaters aren't hard to install really.
Dec 9, 2008. 2:28 AMkillerjackalope says:
With radiators you could add bypass pipes and electronically actuated valves...
Dec 10, 2008. 12:56 AMkillerjackalope says:
Oh I was guessing you had radiators and central heating built in if your whole house is already heated... Kelsey's Ideas would definitely be more simple to introduce to a duct system than installing radiators...
Dec 11, 2008. 7:11 AMkillerjackalope says:
That does seem like an easy option, unless you can find an easy way to heat the single rooms without burning too much electricity...
Dec 9, 2008. 2:43 PMKiteman says:
Or just turn them off by hand...
Dec 10, 2008. 11:53 AMNachoMahma says:
. Most vents have an adjustment - cut back on the unused rooms. If you reduce the flow through the heat box too much, it can cause problems, but shouldn't be a big deal. . To find out how the pros do it, search for "zone heating".
Dec 9, 2008. 8:12 AMkelseymh says:
Yes, there are certainly commercial systems. They are called "zoned HVAC". They work by having a thermostat for each zone connected to a butterfly valve in the duct leading to that zone.
It is inefficient to retrofit an existing forced-air furnace/cooling system for zones. The problem is that the fan is usually optimized for a particular volume flow; by valving off significant portions of the ductwork, you can introduce an impedance mismatch and backpressure, unless the system is able to adjust the fan speed.
Dec 9, 2008. 7:34 PMCameronSS says:
It shouldn't be too hard to adjust fan speed, based on the number of vents open at a given time. If you closed the ductwork cleanly at the base of the branch, wouldn't it eliminate any backpressure problems?
Dec 9, 2008. 6:35 PMkelseymh says:
Yes! Impedance is fancy-talk :-) for "friction" or "resistance to flow." The HVAC system expects to push air through your ductwork at a certain rate (volume per unit time, like cubic feet per minute). If you consider the cross-sectional area of your ducting, then you can figure out the velocity the air has to have to meet that volume flow rate. When you have ducting with branches (or zones), the the cross-section of interest is the total of all the "main" branches. If you block some of those off, then the same volume of air is going to have to be pushed through fewer branches, meaning higher velocity.
Dec 9, 2008. 7:19 PMkelseymh says:
Bingo! If you're taking a fluid mechanics course, you should already be more familiar with this than I am (my undergrad was...ack...24 years ago).
Dec 9, 2008. 7:20 AMCameronSS says:
You could tape cardboard over the vents, but it would probably be better to block the air closer to the source.
As KJ said, you could be selective rather easily with a radiator-type system. My house has radiators along the floor, through which heated water is pumped from the furnace. Electromechanical valves could selectively turn on individual rooms.
You could rig it up with a switchboard, and keep it completely manually operated, or attach it to a small computer/microcontroller, and set everything up on schedules. If you wanted to get really into it, you could carry or implant an RFID chip, and have your presence in a room override the schedule. Apparently Bill Gates' house has a similar system to adjust temperature, music, and lighting.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
