loading
Small 2-stroke Turbocharger
i was wondering if any one had heard of attaching a small turbo charger to a lawn mower or weed whacker , if anyone has heard of it could you explain how, as i am anxious to try this with my recently salvaged 2 stroke and just see as much power i can suck from it.
1-10 of 37Next »
Mcfossil1 year ago
I can speak from a little experience, in my youth I modified a 120cc Kawasaki dirt bike, luckily enough with a rotary valve. I ran this unit on methanol with an injection of giggle gas (nitrous oxide). It was a powerhouse but all being said it did not last too long and if it stalled it would oft times start and run in reverse, the first time it happened it caught me unawares and scared the bejesus out of me. So in short it can be done but it certainly is not good for longevity.
I think your best bet is to keep it naturally aspirated and maximize your current setup with a simple mod like RAM Air Intake. Not only will this increase compression but it will help increase HP, you just have to make sure you adjust your carb so that the air to fuel mixture is correct.
SurfAnt662 years ago
I have thought about this problem and came to the same conclusion that if you fit a turbo chrarger, it will simply just blow all the fuel straight through the engine wasting half of it and probably setting fire to your exhaust, you could turn the exhaust into a afterburner i guess lol, or the other suggestion is using DIRECT FUEL INJECTION, this will only use the ammount needed each stroke so no wasted fuel.
mmenke25 years ago
The edf fan does produce a high volume of air but runs into a problem when the fan outlet has back pressure the airflow will stall @ a pound or so and then your waisting energy creating heat and turbulence. The edf motor with a centrifical supercharger is different less volume more pressure and the faster it spins at every diameter the great both volume and pressure increase there isn't a top end point.Many of the edf's have motors running 25,000 to 75,000 rpm why so high that's do to type of brushless motor used the fastest for top rpm are the type used in radio controled cars high rpm and high power and small edf units the use an inner magnet core windings that surround are switched electronically and due to no iron core it's all about switching frequency. the other type used it edf and model airplanes has a outer magnet field and both motor types your looking for need to have the best rare earth magnets and lowest number of poles for the motor so it generates it's power in the operating rpm range desired. Spinnig a centrifical supercharger low torque requirments a low rpm and this is just what motor recommended loves there are significant number of availible choices in either configuration that would satisfy small engine to engines quite large considering i can walk into a model shop and for less than 350.00 have a 6 horse power motor that the works fits in the palm of my hand would 6 hp @ max rpm of 70to 80 thousand rpm turn a 4 cylinder 2.5l engine into a 5oo hp mini brute power really light weight power plant I know so. This is not as much as top turbo engine output to size but this is not adding nitro nitrous or strangely enough CNG adding a liquified gas as fuel enrichment cools the manifold significantly and has a high octaine rating so its the way to add more to a cooler charge that's denser that does not detonate or ping. Brushless super turbo hmmm well the tuning dynamics and flexibilty turbo that's allways "spolled up" a brake to make the waist gate put on exhast side hmmm . the more enhancement that can be done to the 14psi we live in without using the power of the enigine to do it even if that power has been stored up in advance the higher the output goes for any type and every internal combustion engine any fuel used.
A small electric powered turbo type/centrifical superchargers is what I am looking for myself or just the fan unit. In this case you will want to put the motor mounted in front of the inlet to cool it and the heat transfer at wide open due to max airflow when you need it is minimal.
good luck.
i've been making small blown 2-strokes for the last 10 years and it is indeed possible but there is mutch more to care about than just finding the right blower we rebuild existing turbos to belt driven blowers this is the "best" option for small engines we got around 85 bhp from a 70cc blown scooter engine on alcohol and nitrous
I've heard that using forced induction on 2 strokes doesn't work well since the exhaust is open at the same time as the intake. Thus after a small boost it will just blow through the cylinder instead of into the cylinder.
firemanfu (author)  greasemonkey19868 years ago
thanks for the suggestion, mine is a only a 30cc from a weed whacker. when you say alcohol i am assuming you mean denatured alcohol?
.  Ethanol and methanol will both work.
.  Denatured is most often ethanol plus about 10% methanol, but can have other additives. Check the label.
windigoking5 years ago
has anyone made any progress?
chevy1136 years ago
how would you use a smog pump as a turbo.
1-10 of 37Next »
