solar garage heater
I would like to build a solar panel to heat my garage.  I intend to use a 4x8 used piece of glass, 2x4s, and cardboard tubing.  I can handle this part.  I need help with the air circulation.  I would like to have a solar fan come on when the temp inside reaches 70F.  What parts do I need and how do I connect the parts?
Orngrimm3 years ago
:) I have 5-10 arduinos at hand all the time... Thats why i often go with this option.
But those reptile-switches are cool! Didnt knew they existed and can be set at a free choice-temperature. Good to know! :)
But as far as i can see, the cheapest are in the ballpark of 60$ a pop. But the benefit is definitely the simplicity of the build: No building at all. Just install and use.
It seems to be a tradeoff: Cost vs. simplicity
Ah... Found a nice one for around 30$. For sure a price you can pay for such a project if i think of the other costs involved for the hotbox.
http://www.thermomart.com/thermometer-heater-plant...
Don't understand why these days everyone thinks an Arduino is necessary for the most basic tasks...
I simply assume you got mains power in your garage...
Use a thermo switch as used for reptile enclosures.
These units can be set for a specific temperature and provide the option to either turn a device on or off depending on the temp and with geat accuracy.
Simply connect your fan and place the temp sensor in a spot that gives you good readings, not under the roof or on a cooler wall for example.
Set the temp for the switch unit and specify if you need the on or off state as normal - in your case it off as you want to turn the fan on when the temp is reached.
If you are a bit into electronics you can also use a NTC or PTC resistor and some transistors to switch the fan.
Suitable circuits are available and I post some links if you need them.
Orngrimm3 years ago
If you are a bit capable of programming, the simplest solution would be a little Arduino with a Temperature-Sensor like the cheap TMP35 or TMP36.
The skeleton of the code would look something like this:
- Delay
- Read both analog-voltages of the sensors
- Decide if air from the Outside is hotter than the inside-Air. If Yes:
- Check if inside-Air is below 70°F. If Yes:
- Switch Fan on which draws warm Air in from the hotbox.
- Loop up to delay
It would be a pretty straight forward code. I could help you with it if you want...
To your question about the parts: Any Arduino would do. I would suggest a TMP36 as sensor. Connect them like shown here:
https://learn.adafruit.com/tmp36-temperature-senso...
The TMP36 is around 4$ at your local electronics-shop or on Amazon.
An Arduino is also cheap. If you want a bigger UNO R3, you can go with something like 3$ (shipped) http://www.aliexpress.com/item/Free-shipping-high... or if you want a smaller one (simpler do conceal in a project-box) a Nano V3.0 for around 4$ (shipped) http://www.aliexpress.com/item/For-arduino-Nano-3-... would fit the bill.
I added a quick and dirty sketch on http://pastebin.com/cMdXbn7A
Also i forgot: The fan will need to be switched with a normal or solidstate-relais or FET/Transistor.
