stereo audio amplifier lm386 (i need some help)
any ideas if this would work (i'm a total noob on this)
red=negative
blue=bass boost
black= ground
any suggestions on how to:
make it work?
make it sound better?
louder without distorting?
make it more suitable for mp3player/ipod?
how to add (and where to put) high and/or low pass filter?
the 10k log pot should serve as volume control (hope that's correct XD)
my jack's all wrong i need 1/8 stereo jack....so how do i put that ?
how many watts for the speaker?
is a 9 volt enough to power this ?
would the switch on the bass boost work?
Picture of stereo audio amplifier  lm386 (i need some help)
What schematic are you going off of for this?
Here are a couple of basic LM386 audio amp circuits. But they are all mono amps. If you want stereo then build a pair of the circuits. Then either use 2 separate pots or buy one that has a single shaft that controls 2 variable resistors. If you combine the left and right channels into a single pot you will loose about half the signal strength going into the amp.
What's it supposed to be ? Draw a real circuit diagram !
