tec power options
i was wondering where the best place to ask a question would be,
ive been playin with peltiers lately
and the ones i have are 0-16v 026A
i was wondering if there was any way to make a power supply for them
or some way to usa like a car batt. i was just worried as my deepcycle is like 1200 amp
dont really want to blow up my 30 a piece tec's
the goal eventually is to mount like 10 to the undersides of an old aluminum icetray
so i can submerge the bottom in water and fill the tray up, flip the power switch and in like 40 seconds have myself some icecubes
1-10 of 17Next »
lemonie7 years ago
A 12V deep cycle battery will be just fine, never mind what it can output.
These things are not very efficient, and need effective cooling on the hot sides.
L
Isn't there a bracket of temperature differences when they're at their best... Aim for that?
Yes, but the reason professional refrigeration-engineers don't use Peltiers is that they are "shite" for it.
L
furry1 (author)  lemonie7 years ago
if i recall the temp difference is 180' from the hot side,
so if i have the heatsinks of the hot side submerged then i should be able to get about -150' ish easy with just cool water,
a bucket of water should absorb the heat of a cup or two of the soon to be ice water (making up for the bad efficiency )
but the question isnt the tec's or the efficiency.
its how do i take a car battery and connect it to output 0-16v at 0-25 amps per line
times however many lines i decide to use
lemonie furry17 years ago
Do you need 0-16V, or would 12V do you?
Just wire them up in parallel.
But do read up on 'em - http://www.heatsink-guide.com/peltier.htm
L
it will take anywhere from 1 volt to 16 volts
so id say i want anwhere in the 12v - 16v range
at anywhere above 15 amps to say 26 amps which it the max rated for each unit
Use the battery as is, or listen to steve'.
L
it just dosnt seem right to just connect two wires to a car batt.
it seems to simple
and none of you are actually answering the question
how do i
take car batt
and make (whatever) 8/12/16 volt (whatever) 10/15/20/25 amp lines that will go to each unit
or the array of them in parallel
do i simply need a wire and a fuse and hook em up ?
or what?
You need a PWM based amplifier, in an H bridge
furry1 (author)  steveastrouk7 years ago
what waht what???
1-10 of 17Next »
