loading
transformer power
I have been thinking about this for a long time now and in therory it works.  What im wordering is if you could make it work in place of the traditional power outlet.  Here it is, basicly there are just coils of wire inside of a transformer, on coil has say 240 turns of coil. Inside of this coil is another coil with 240 turns also.  So the voltige inside the first coil will be the same as the second coil.  And to half the voltige in the first coil.  If you had a plug that was just a cilender with a coil of wire inside and an outlet that was a hole in the wall with a coil inside.  I know a hole in the wall with 120 volts running through it sounds scary , but put a plastic cylinder inside the hole and vurtaly no shock hazerd.
sorry for the spelling errors spell check was not working.
NachoMahma7 years ago
.  As lemonie points out, what you are describing is called inductive coupling or a transformer. Unfortunately, efficiency is directly related to frequency. At 50/60 Hz, efficiency isn't very high. Plus, the insulation required for consumer safety would further decrease efficiency by increasing distance between elements.
.  From a safety standpoint, you have a great idea. From a "green" point of view, not so good.
.  Ie, a great idea for wet locations (even underwater), childrens' rooms, higher frequencies, &c, but not so good for general use.
lemonie7 years ago
Inductive coupling. These would be big and heavy and contain a lot of metal. And probably buzz, certainly lose a bit of power. It could be done though.
L
