usb to fm transmitter
 Hi,
I am a very big noob to wiring.
For a present, I wanted to make my cheap old AAA powered fm transmitter into a usb powered one.
Thinking I was so smart, I cut up an old usb cord and soldered the red to positive and black to negative.
It worked great until it started melting the transmitter.
So I now I realize that usb is much more powerful than 2 AAAs.  heh heh.
I found this:
www.instructables.com/community/USB-to-Travel-Clock-Circuit-Help-/
but it's a bit over my head.  I'm assuming I need to get a capacitor or voltage divider but I could use a little help breaking it down into noob speak.  Plus the transmitter is a little thing, 2 inches, is there a smaller way of checking the voltage?
K, thanks bye!
Jayefuu7 years ago
So you have 5V and you want 3Vish?
This should do the job. It's used on a pcb I own for converting 5V to 3.3V for an SD card reader. You'll also need 2 x 1μF ceramic capacitors to stabilise the input and output voltages. Page 2 of the data sheet shows you how to use them.
That solve your problem? :D
audrywolters (author)  Jayefuu7 years ago
Thanks!  Looks perfect!  Very small and right voltage.
But I looked at the data sheet and it all went over my head
Could you tell me what I'm to solder to what?
I think I get that the usb goes to the middle prong (Vin)
and Vout would go to the board
but what is the GND?
and where to the capacitors go?  one to + and one to - but which side?
Sorry, total newbie.
Thanks!!
audrywolters (author)  audrywolters7 years ago
 Oh, capacitors go on both ends!
But how... where... i not know  *-*
