COMMUNITY : FORUMS : BURNING QUESTIONS
volcano with light
hi guys! i'm sorry if i'm here to disturb....
i need to build a lamp.. with shape of a volcan....  now y have this problem.... how can I create the movement of lava running down the slope, with the lights? I thought the catenary Christmas, with the movement to fall, but the problem is to recreate the color change down ... anyone have any ideas on this?
than you to all for helping.. :)
mpilchfamily says: Oct 11, 2012. 5:26 AM
You will want to make a spinning lamp. Your outer volcano shell will have transparent areas where you want the lava flow to show through. Inside suspended over the light you will need a translucent cylinder that can spin on a needle over the bulb. This cylinder will have your lava pastern on it. Much like the picture below. As it spins it will give the effect of flowing lava.
In the image the piece in the center sits over the light and is balanced on a needle over the light. The top of the cylinder is vented so the heat from the bulb will keep that cylinder spinning. As the light shines through it the pattern is seen on the outer cylinder. In this case it creates a swirling effect and makes the bear logo flash go from swirling to fully light and back again as it spins.
This is the same method used in fake fire places to give the effect of a real fire on the back wall of the unit. The hard part for you will be getting a translucent lava like pattern made.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
