wiring a lot of LEDs, don't know the math. please help
19
comments
Add Comment
If we assume 20mA for each LED, you'd need 3.7A at 3.4V, if you put them all in parallel. Not sure where 'Muff gets the 300mA @ 5V from.
You definitely don't want to put them all in parallel though. I'd suggest putting a bunch of LEDs in series with one resistor, then putting a bunch of these in parallel.
For example, if we want to feed with a fairly standard supply voltage of 24V, we can afford to put 7 LEDs in series (7 x 3.4 = 23.8V). Plugging this into the calculator FrenchCrawler mentioned gives you a 10 Ohm resistor. Now just put 27 of these in parallel, for a total of 189 LEDs.
End result: 540mA at 24V, using 27 resistors of 10 Ohm.
3.4V x 20mA x 187 = 12.7W
or if you want to include the resistors in my setup above:
24V x 20mA x 27 = 13W
Efficient though LEDs are, most of this power will actually be emitted as heat, not light (typical luminous efficiency for LEDs is around 10%; incandescent bulbs are only around 2-3%).
Depending on the physical design of your circuit (are you trying to cram 187 LEDs in as small a space as possible?), a heat output of 12-13W may or may not be a problem.
I'd be more worried about the amount of UV light this is going to give off. You're not going to get a sunburn, but you probably want to avoid looking at this array with the naked eye, because you might do some serious damage without even realizing the LEDs are on...
Danger of Eye Damage From Visible Light Emitting Diodes
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
