Introduction: Double Compartment Micro Tackle Box.
Carrying around a big tacke box is hard work.Make that hard into easy work with this instructable.
Step 1: The Supplies:
What you will need for this project:
- 2 Altoids things
- 1 Hot glue gun
- 1 Clothes pin
- Popsicle sticks
- Hot glue sticks (for the hot glue gun)
- 1 Sharpie marker
Step 2: Making the Hook Holders
(you can make what ever size you want). First put your supplies in neat order(like you would have walls). Then draw with the sharpie around your hooks.(Those will be the walls). Next, dump out every thing and cut your popsicle sticks to the same length as your lines. When you are done cutting all of your pieces glue them down. When they are all glued down do it to the other altoids can.
Step 3: Putting Them Together
When you have completed making the hook holders glue the 2 altoids cans together. Once that is all dry glue the clothes pin. Then put in all the lures and hooks inside and you can just clip it on your pants and you will be ready to go fishing.
