Introduction: Duct Tape Boat [transparent]
this instructable ill show you how to make an duct tape boat.
you can make this with Scotch Tough Duct Tape but use an transparent one.
its isn't remote controlled just in controls itself
Step 1: That You Need
you will need :
1 roll of duct tape
some wooden sticks
tool:
scissor
for the electronic:
1× 12v fan
1×9v battery
1×9v battery holder
switch
Step 2: Bottom
cut down four of the wooden sticks at 15 cm (5.9 inches).
then cut down 10 cm of the remained pieces.
Step 3: Front of the Boat
now we will make the front of the boat.
cut down 2×10cm of the wooden sticks.
then put it in triangle to the front side of the bottom plate like on the picture.
after stick them to each other and also stick the to the hole between them. if you did it stick the triangle(that you have made)to the bottom plate.
Step 4: The Sides
cut down 5×5 cm tall sticks and fix them down to the corners . if you have finished join them whit duct tape. don't forget the corners .
Step 5: Upper Front Side
this step is very similar to the third.
make that triangle twice.and stick it to the sticks that you left standing.
Step 6: Curcuit
put the battery holder on the battery. grab the red wire and directly connect to the fan's red wire.
grab the black wire and connect it to the switch' s first connector. the black wire of the fan is connected to the second connector of the switch.( look at the second picture to know witch is witch)
then place it into the boat
Step 7: Make It Waterproof
use an household film (like on the picture) to make it waterproof cover.cover the body of the boat. do not cover the fan !!!!
after you covered, fix it whit some duct tape.
Step 8: Enjoy!
this is my result:
http://www.youtube.com/watch?v=loWpwg2fXqY
The Great Outdoors Duct Tape Contest
