3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
"Beating" LED Heart T-Shirt
\"Beating\" LED Heart T-Shirt
As you all may or may not know, I love LEDs! Now, since the title of the contest is "Show Your Heart Valentine's Day Project", what could be more appropriate than a Beating LED Heart on a T-shirt?
Here's how YOU can show YOUR Heart on Valentine's Day!.... or force your valentine to show his/hers. ;-)
Step 1Get the Materials
Get the Materials
You Need:
A T-shirt that you are willing to sacrifice in the name of love
99 3mm red LEDs (1.8-2.1V @ appx 10 mA)
two DM7474 IC's (flip flops)
one DM7402 IC (2 input Nor gate)
one ne555 timer
one 224 pf capacitor
one .47 uf capacitor
two 4.7 uf capacitors (over 9 volts)
.01 uf capacitor
one variable resistor (100k ohm max or a 47k resistor)
one 470 ohm resistor
two 1k ohm resistors
one 560 ohm resistor
1 nine volt battery + clip
Foam
Tape
Hard Drive cable (or wire)
Telephone cable (not needed but helpful)
Another T-shirt or some fabric
Needle + Thread (or a sewing machine)
wire cutters
Soldering Iron
Solder
pm me for the original heart template, I don't know how to attach original jpegs
43 comments
1-40 of 43next »
Oct 17, 2011. 2:42 PMDekubaba94 says:
How can you wash it, and isn't it too stiff to wear?
Jul 7, 2011. 10:07 PMkscientist says:
is it possible to use a shift register(IC 7495) instead of flip flops??? if possible type of operation has to be used?
Jun 30, 2011. 10:15 AMkscientist says:
can u help me??
am doing a star of this same pattern....i dont want any heart....if i do in this same pattern n if i add few more leds wil tat affect the circuit stability ?? can u plz help me ....
Jan 22, 2008. 3:07 PMstasterisk says:
Hey - check out this kit the electronics goldmine is selling.
Jun 17, 2009. 9:06 PMGoodhart says:
Did you see what ThinkGeek has in this line (wireless LAN detection, mutual shirt detector, etc)
Jan 2, 2009. 2:29 PMcomputer_guy says:
Wait, how are you going to wash it?
Oct 12, 2008. 11:23 AMlinkz says:
how much did this all cost?
Oct 12, 2008. 11:34 AMlinkz says:
oh and where can i get the materials from?
Jan 5, 2008. 12:13 PMShifrin says:
Wow, this is really great! It would make a great Valentines day gift! To bad I have no one to give it to... : ( ~Shifrin
Jan 6, 2008. 10:52 AMShifrin says:
Will do : )
Jan 3, 2008. 9:33 PMjohn917v says:
Awesome! That is a great idea for a V-day project.
Apr 16, 2007. 5:52 PMphenoptix says:
Sweet work, I like it a lot, pop by if you fancy doing any more LED mods and I might be able to help you out.
Apr 17, 2007. 1:58 AMphenoptix says:
Ideas, no... SMD LEDs yes! PM me and I'll get some to you so you can have a play. Using kynar wire will neaten it up a bit too!
Dec 2, 2007. 1:52 AMphenoptix says:
Fantastic- I'll keep an eye out for them!
Sep 14, 2007. 1:14 PMnaru_rules says:
can u translate wat i need into something i can understand
Jul 29, 2007. 8:45 AMavin says:
Hello, me again :P I almost forgot to tell you, you wrote wrong here on your specification. You said on the specification "one DM7492 IC (2 input Nor gate)", it was suppose to be DM7402 right? :P DM7492 isn't a NOR gate chip ;-)
Jul 23, 2007. 6:50 AMavin says:
Hi this is nice :P i am planning to make it on a PCB and i am wondering if i can replace those 2 LED that you use to drop the voltage to 5V with resistor? if so what value should i use? is it 100ohm? PS: the wireing on PCB is hell :P i will probably end up with burning every single LED :P
Jul 23, 2007. 10:50 AMavin says:
what do you mean by glass diode? is it zener diode? i am also alittle bit confused over the 560ohm resistor in serie with all those leds. My calculation says that you are giving each LED 0.34mA on the outer ring with 42 LEDs, am i missing something here? 0.34mA sounds abit low....?
Jul 28, 2007. 2:21 PMavin says:
Hello again, so i end up using a Green LED to drop the voltage down to 5V into those IC :P and here is some picture that you wanted to see. The routing is very messy :P i was too lazy to fix it so i let most of the work be done by auto-route.
Jul 28, 2007. 8:00 PMavin says:
Your instructables was a good idea :) i like it hehe
Jul 8, 2007. 8:28 PMchatterbox14730 says:
Does it involve a battery pack?
Mar 4, 2007. 9:12 AMphasingtwins says:
great job you should give your wiring more slack so they won't break in your pocket ;]
Mar 4, 2007. 9:32 AMphasingtwins says:
gg
nice
Feb 22, 2007. 8:28 PMmever says:
Great project Muffinator, love the detail you put into the instructable. Your notes are so good i only need the video to see the end result. Still its nice to see you got the video uploaded to YouTube. It dose make it easer for people to see. The hard work on this really shows.
Feb 25, 2007. 11:54 AMmever says:
same here, comments are like brain food. Alot of experience to learn from.
Feb 23, 2007. 7:01 AMZujus says:
Very nice job! ;) Idea is just great! ;)
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
80
Author:T3h_Muffinator(olopede)
I'm a just a not-so-average human with a passion for making. I see a world of hackers, makers, and producers as the sun rises in the near future. I'm starting olopede, an educational electronics k...
more »
