3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
"Beating" LED Heart T-Shirt
Step 4Make the Flip-Flop-O-Matic
Yeah, pretty much just follow the schematic again, This one's a bit more complicated.
All arrows that have letters on them DO NOT go to ground, just follow that and you're set.
I did this on a breadboard first to make sure it worked, then transferred it to perf, you could do the same if you want.
Warning: Scientific Content
The two flip-flop chips are wired to create a 4 bit shift register, this shifts a high (1) through 4 initially low (0) state bits. The high bit is shifted every peak from the timer chip. when it gets to the 4th bit the chips reset and start back at the first chip. The 2 inut nor is used to determine at what time each row of leds will light. When there is a high (1) at either input the leds will not light, but when there are no highs the leds will light. It's a simple circuit, but as this was my first time using digital logic, I am SUPER excited.
5 comments
Jul 7, 2011. 10:07 PMkscientist says:
is it possible to use a shift register(IC 7495) instead of flip flops??? if possible type of operation has to be used?
Jul 23, 2007. 6:50 AMavin says:
Hi this is nice :P i am planning to make it on a PCB and i am wondering if i can replace those 2 LED that you use to drop the voltage to 5V with resistor? if so what value should i use? is it 100ohm? PS: the wireing on PCB is hell :P i will probably end up with burning every single LED :P
Jul 23, 2007. 10:50 AMavin says:
what do you mean by glass diode? is it zener diode? i am also alittle bit confused over the 560ohm resistor in serie with all those leds. My calculation says that you are giving each LED 0.34mA on the outer ring with 42 LEDs, am i missing something here? 0.34mA sounds abit low....?
Jul 28, 2007. 2:21 PMavin says:
Hello again, so i end up using a Green LED to drop the voltage down to 5V into those IC :P and here is some picture that you wanted to see. The routing is very messy :P i was too lazy to fix it so i let most of the work be done by auto-route.
Jul 28, 2007. 8:00 PMavin says:
Your instructables was a good idea :) i like it hehe
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
80
Author:T3h_Muffinator(olopede)
I'm a just a not-so-average human with a passion for making. I see a world of hackers, makers, and producers as the sun rises in the near future. I'm starting olopede, an educational electronics k...
more »
