"Cozee-Robe" With Handsleeve and Booties
Introduction: "Cozee-Robe" With Handsleeve and Booties
After years of working in nursing homes and hospitals, I have learned the extreme value of a good lap robe. Our elders, whether living within institutions or recovering in a hospital setting, depend heavily on the care that they receive from family and staff.
The geriatric body undergoes physical changes that include atrophying muscle tissue, thinning skin and slower circulation, all contributing to a greater sensitivity to cold. Your elder Loved One's hands and feet are often - if not always - cold.
I have designed a lap robe that not only provides the warmth of cover but an added resistance to chill by the addition of attached booties spaced two feet apart to accommodate wheelchair footrests and a flannel panel located at lap-level in which to tuck cold hands.
Built to last and sans the frills, this soft, comforting robe can withstand even those rough cleanings from institutional machines.
Tucked, wrapped and cuddled within one of my "Cozee-Robes", our elders may experience the next best thing to loving arms.
You will find the pictured, western-themed "Cozee-Robe" available in my Etsy shop (www.susanclare.etsy.com) for $35.00. Shipping is free, my gift to the purchaser, an added incentive to get this robe to that certain person who needs it. Thank you for this opportunity to offer something good to the world.
Susanclare's Etsy Shop "Cozee- Robe"
Step 1: Supply List
1. basting thread - contrasting color to fabric
2. machine thread - color of fleece fabric
3. fabric marking pencils
4. fabric - flannel (4' x 6') a flannel sheet would work just fine
5. fabric - fleece (4' x 5' 6" approx.) "themed" panel - I chose a western theme
6. scissors
7. sewing machine
8. sock "booties" size medium or large
9. ruler or measuring tape
10. seam-ripper, pins, basting needle
Step 2: Fabric Prep - Pre-wash, Trace and Trim
Pre-wash fabric and booties to remove excess dye and minimize shrinking. Dry and press fabric.
Position fleece panel facing down. Using fabric pencil, trace a (3' 8") x (5' 3" ) dashed line rectangle within the panel. Mark match points at corners and every ( 6") along dashed line of each side. Trim, leaving ( 1/2" ) seam allowance.
Repeat process with flannel piece. Excess flannel will be used to make Handsleeve.
Step 3: Prepare Handsleeve - Trace and Trim
Using fabric pencil, trace an (8" x 12" ) dashed line rectangle on the excess flannel piece. Cut out, leaving ( 1/2" ) seam allowance.
Step 4: Prepare Handsleeve - Pin, Baste and Machine Stitch
Position fabric piece face up. Turn fabric's seam allowance to inside and pin, then baste.
Machine stitch fabric using matching color thread, (1/4" ) from edge, all the way around. Remove basting thread, trim "tails", set aside.
Step 5: Robe Assembly - Position Fabric, Pin at Match Points
Place flannel and fleece pieces together, each facing out. Pin together at match points.
Step 6: Robe Assembly - "Quilt" Fabric Pieces Together
Position robe flannel side up and, using thread that matches fleece, machine stitch a "quilting" seam, spaced (1) foot from left edge of robe.
Begin by placing a backstitch (1/2) inch below top hash marks then stitch downward, paralleling left edge of robe, stopping and backstitching (1/2) inch above bottom hash marks to secure.
Repeat "quilting" seam (3) times, each spaced (1) foot apart, paralleling the first seam. Fabric pieces are now permanently secured together.
Step 7: Attach Handsleeve - Center, Pin, Machine Stitch to Secure
Place robe flannel-side up, making sure fleece panel's "picture" is positioned appropriate to the placement of the Handsleeve . Place Handsleeve on flannel crosswise, facing up, centered on robe's mid -line and positioned (1) foot below top edge of robe.
Pin Handsleeve to robe. Using thread that matches fleece, machine stitch (1/4) inch from edge along top and bottom sides to secure, leaving left and right sides open for hand placement.
Step 8: Booties - Position and Attach
Place robe flannel-side up, making sure that fleece "picture" is positioned appropriate to position of Handsleeve and booties.
Place booties on flannel, facing down, toes pointed downward and heels facing out so that booty sleeve edges are (1) foot above bottom edge of robe, spaced (2) feet apart from robe's centerline.
Pin front edges of bootie "sleeves" to robe, baste then machine stitch, using thread that matches fleece, about (3) inches across each bootie sleeve, leaving (1/4) inch seam allowance. Double stitch for added strength then remove basting thread, trim "tails".
Step 9: Finish Robe - Fold in Seam Allowances and Pin
Position robe flannel-side up. Moving from left to right along edge, fold in fleece and flannel's seam allowances and pin together.
Step 10: Finish Robe - Machine Stitch Edge
Machine stitch fabric together, (1/4) inch from edge, all the way around, using thread the same color as the fleece. Trim thread "tails"...and you are done. Someone is in for a warm surprise!
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    Susan, Could you email me photos of the finished Cozee-Robe too?
    Thanks so much!
    Hi. I really like how this sounds: perfect for my mom who had heart surgery. But I'm having trouble picturing how the whole thing looks. Could you email me a photo? I'm afraid I'm a visual person, and a picture of the item folded up doesn't help me. Thanks.
    Hello there! So glad you like the idea! I will send an image via email or through Instructables, your choice. If you want it via email, please send me your email address. Thanks, Susan R.
    I made one of these today for a friend undergoing chemotherapy. It was a quick project. If I make another one, I'll probably sew the fleece and flannel right sides together first, turn them right side out, sew up the little gap, and then do the quilting seams. If I pin it in the right places, I think I can keep it straight. That pinning and hemming around the edges after the quilting seams had been done drove me crazy! (Patience ain't my strong suit.)
    Thank you very much for suggesting I wash the material first. The fleece shrank like crazy. If I were a nice person, I would have run back to the store to buy more, or I would have seamed another big strip of fleece to keep the proper length (top to bottom, that is). I am just not that nice, I'm afraid. The lap robe ended up being about six inches too short for me to sew on the booties. They'll be a separate gift.
    I love the softness and warmth, and especially the weight, of this lap robe. It has the heaviness of a spa robe and blanket, and the handsleeve is a lovely feature. I think my friend will be very happy.
    I like your idea about when to do the quilting seams! It makes me feel great to know that your friend will be benefiting from my project! I think they would make a good gift for residents in convalescent centers and nursing homes. Thanks again, Susan
    This is beautiful, lovely, thoughtful and all things good and generous! Thank you for sharing your method, and for thinking of inventing this! I'll be sending one to my 96 year old great uncle for (insert Winter Holiday of choice here) and one to my grandmother, who can get cold in Miami in July (big thermoregulation issues) Thanks again! .
    Just saw your comment, it totally warms my heart that you made cozee-robes for your elderly loved ones. Thanks so much! Susan Rivera
