Introduction: "Deux" K'nex Ball Machine
Pieces:
4 Grey Rods
8 Red Rods
72 Yellow Rods
163 Blue Rods
100 White Rods
111 Green Rods
7 White 8-Slot Connectors
59 Yellow 5-Slot Connectors
14 Green 4-Slot Connectors
45 Red 3-Slot Connectors
3 Grey 2-Slot Connectors
17 Orange 2-Slot Connectors
79 Grey 1-Slot Connectors
32 Orange Tabbed Connectors
52 Blue 3D Connectors
87 Purple 3D Connectors
6 Brown Tabbed Connectors
6 Red Gears
58 Chain Links
3 Balls
1 Motor
Total: 957 Pieces
Step 1: The Structure, Part 1: the Base, Part 1
This is the base part one: The structure base.
Parts:
27 Blue Rods
23 Blue 3D connectors
19 Purple 3D connectors
13 Yellow Rods
Total: 82 Pieces
Step 2: The Structure, Part 1: the Base, Part 2
This is the second part of the base, the extra parts in the base
The Motor
The Motorhouse
The Path
Parts:
14 Green Rods
11 Grey 1-Slot Connectors
10 Blue Rods
8 Purple 3D Connectors
6 Yellow 5-Slot Connectors
6 White Rods
5 Orange 2-Slot Connectors
5 Brown Tabbed Connectors
3 Blue 3D Connectors
2 Red Rods
2 Yellow Rods
1 White 8-Slot Connector
Total: 73 pieces
Step 3: The Structure, Part 2: the Tower
This is the tower segment of the machine. It is a long step. This is where all the components are connected.
It comprises of seven sections/floors
Pieces:
65 Blue Rods
44 Purple 3D Connectors
35 Yellow Rods
34 Green Rods
23 Blue 3D Connectors
15 Yellow 5-Slot Connectors
6 White Rods
4 Red Gears
4 Red 3-Slot Connectors
4 Grey 1-Slot Connectors
2 Green 4-Slot Connectors
1 Orange 2-Slot Connector
Total: 238 Pieces
Step 4: The Structure, Part 3: the Path Seperator
A short step. This component makes the ball go to either path one or two.
Pieces:
8 Grey One-Slot Connectors
4 White Rods
4 Blue Rods
2 Yellow Rods
2 Yellow 5-Slot Connectors
1 Green Rod
1 Red 3-Slot Connector
1 Brown Tabbed Connector
Total: 23 Pieces
Step 5: The First Way, Part 1: the Three Paths
These are three identical paths that begin the first Way.
Pieces:
18 Grey 1-Slot Connectors
18 White Rods
15 Blue Rods
12 Yellow 5-Slot Connectors
12 Red 3-Slot Connectors
3 White 8-Slot Connectors
Total: 78 Pieces
Build three, then connect to tower as shown.
Step 6: The First Way, Part 2: the Fourth Path
This is a single path after the Three identicals.
Pieces:
6 White Rods
5 Grey 1-Slot Connectors
4 Yellow 5-Slot Connectors
3 Red 3-Slot Connectors
3 Red Rods
2 Green Rods
1 Blue Rod
Total: 24 Pieces
Step 7: The First Way, Part 3: the Fifth Path
This is a fifth path leading to the spiral in the first Way.
Pieces:
7 Blue Rods
7 Red 3-Slot Connectors
6 White Rods
2 Grey 1-Slot Connectors
2 Purple 3D Connectors
1 Green Rod
1 Yellow Rod
Total: 30 Pieces
Step 8: The First Way, Part 4: the Spiral
This is the last part in this Way, the spiral. it is an easy but long and repetitive step.
Build seven of picture two and one of picture three. Connect them all, then put the Grey connectors on a re rod and put two more Grey connectors on. Then place in the empty spot on the ball tower.
Pieces:
16 Yellow Rods
14 Green Rods
8 Yellow 5-Slot Connectors
1 Red Rod
Total: 64 Pieces
Step 9: The Second Way, Part 1: the Supports
These will support the Two Slides.
A fairly short and easy step.
Pieces:
6 Red 3-Slot Connectors
4 Grey Rods
4 Blue Rods
2 Yellow Rods
2 Orange 2-Slot Connectors
2 White Rods
2 Green Rods
1 Red Rod
Total: 29 Pieces
Step 10: The Second Way, Part 2: the First Slide
This is the first Part of the second Way. There is a special guard part that you need to build(Picture 6), otherwise the ball will fall off.
Pieces:
16 Orange Tabbed Connectors
10 White Rods
8 Blue Rods
7 Green Rods
1 Yellow Rod
1 Grey Connector
Total: 48 Pieces
Step 11: The Second Way, Part 3: the Ball Stopper
A Short Step. Slows the ball down.
Pieces:
5 Green Rods
1 Blue Rod
1 White Rod
Total: 13 Pieces
Step 12: The Second Way, Part 4: the Descent
This part is where the ball slides down. It is an easy step. Build, connect Step 11, and attach to the mainframe.
Pieces:
Step 11
24 Orange Tabbed Connectors
24 White Rods
11 Blue Rods
2 Green Rods
Total: 65 Pieces
Step 13: The Second Way, Part 5: the Loop
This is the part of the Way that goes upside down.
Pieces:
16 White Rods
8 Orange Tabbed Connectors
8 Green 4-Slot Connectors
4 Blue Rods
Total: 36 Pieces
Step 14: The Second Way, Part 6: the Box
This is a boxy part that catches the ball after the loop. It is a short Step. Build it then attach it to the tower
Pieces:
19 Green Connectors
12 Purple 3D Connectors
7 White Rods
2 Red Rods
2 Blue Rods
2 White 8-Slot Connectors
1 Yellow Rod
Total: 51 Pieces
Step 15: The Second Way, Part 7: the Tubing
Now, you must attach the tubing. This can be very frustrating. First, attach the shorter pieces to the top Slide, then the longer ones to the bottom slide.
You need:
2 Pieces of 102cm Orange tubing
2 Pieces of 37cm Orange Tubing
Step 16: The Chain, Part 1: the Grabbers
These are the little bits that grab the balls and lift them up (Yoinks!) Build four of them. Make sure all chain links face DOWN.
Pieces (Total):
12 Chain Links
12 Orange 2-Slot Connectors
12 Green Rods
12 Grey 1-Slot Connectors
8 Silver Spacers
4 Blue Rods
4 Grey 2-Slot Connectors
Total: 64 Pieces
Step 17: The Chain, Part 2: the Excess Links
Now, You have to Build Four sets Of Chain links. Two Sets have to be 12 and the other two have to be 11.
Pieces:
46 Chain links
Total: 46 Pieces
Step 18: The Chain, Part 3: the Connection and Application
In this step you will connect steps 16 & 17 and place the finished product on the Ball Tower, thus completing it. When you Put on the chain, The chain will be very Tight.
You Will Need:
Step 16
Step 17
Step 19: How to Use
I think this Is a bit Self explanatory, but I will tell you anyway.
Pieces:
3 (K'nex) Balls
To Turn On the Ball Tower, Press the Motor Switch LEFT.
The Machine Runs Optimally With Three Balls, But will handle one or two as well, but NOT four.
Congratulations, You have Finished Project DEUX!!!
Step 20: Troubleshooting
The DEUX is an advanced piece of K'nex machinery, but it does have its flaws. Here are some Common Problems.
P: My motor is not Running.
A: Either the batteries are dead or the motor is broken
P: The Ball Gets Stuck On the three Identical Paths.
A: Push the edges apart or remove the grey connectors on the paths.
P: The ball Does Not Make It over The loop
A: Check If the Tubing Is on correctly
P: The Ball Grabbers Always Snap off!
A: Try removing the central Grey Connector From the path in the base.
If you have any other Questions, PM me and I will post the Solution
You For Reading,
-TM2k
