Materials you'll need are:
1. Big, strong magnet (or several small ones. I used my modified 6x8 speaker magnet)
2. Little, strong magnet (I used one of my magnetic darts)
3. Hoe (optional)
4. Plastic sandwich bags
5. Mortar and pestle
6. Small container and a lid
7. Large container
Remove these ads by
Signing UpStep 1Finding a good fishing hole....and cast out.
One of the best areas to find a good source of ferrous metals is the ground....No seriously, where do you think metal comes from? Don't answer that...
A mixture of gravel and sand is usually one of the better spots for this (beaches are also great, but I'm not there).
1. Use the hoe to break up the surface of the ground into a small pile of dirt.
2. Put your large magnet into one of the sandwich bags and hold onto it with your hand. Keep the large container close by.
3. Now start to sweep the ground as shown in the last picture. You can push the pile of dirt out, to get at the metals underneath. Move your hand with the magnet around as if you were washing the ground....
http://64.176.180.203/charcoalretort.htm
but i blacksmith with it, so i need much larger amounts than you will, so your method if perfect 4 u.
oh, and did u know that those vapors coming from the can are flammable?
Just to point out your link is broken. I don't know if this new one compares to the broken link, but it reads good.
http://www.puffergas.com/historic/rules/rules.html
Cheers
http://www.twinoaksforge.com/BLADSMITHING/MAKING%20CHARCOAL.htm
yeah id expect that they gases would be flammable, although i thought the majority was water vapor, might depend on the wood. like eucalyptus as opposed to pine.
i like the idea about re directing the vapors back and using them to do the cooking though, good idea that one.
yeah i would use 200L or 44gal drum (same thing) but i dont have one that i can use. all have/ had elf fuel in them. explosion if not washed out properly = do not want.
by the way cool 'ible
liked it alot!!!
But instead of ink you use these filings and mix them into some vegetable oil (you need more filings then oil).
2. Used by teachers to demonstrate how magnetic fields work.
3. Can also be used to entertain kids. Give them a bag of iron filings, a magnet, and a piece of paper (or flat container) and they'll be memerized by how the filings interact with the magnet.
4. If you have alot of time on your hands and a good furnace, you could melt the filings together a start making your own metals. Which then you could turn into magnets or other fun objects.
