In regions without a wired LAN infrastructure, 2.4GHz IEEE802.11b/g "WiFi" increasingly allows a attractive datacomms pathway at modest end user & setup cost. However (given successful WiFi links are still rather a black art!) it'll be the boring things which will limit success,blow budgets & frustrate. And by boring we mean costly copper cables, specialised connectors, aluminium sections & plates, plastic housings, sturdy fasteners,mount poles etc. Allow $$$ ...
As part of an altruistic 2004 NZ student project,it was realised cheap USB WiFi adapters, in conjunction with reflective parabolic cookware, could offer a cost effective workaround. The USB approach appealed since -
- All the microwave-data decoding is done right in the USB "key", so no cable losses occur.
- Regular cheap USB extension cables (to some 5m) & connectors can be used to locate signal localised sweet spots, perhaps with auditing software such as Netstumbler.
- USB "keys" are cheap (~US$10),although their power output may be low (~40mW).
- Easy swap outs for testing assorted reflectors & adaptors results.
- The USB keys can readily be mounted at the focal point of suitable parabolic reflectors, yielding gains of ~12dB at little cost with just cookware,sieves,woks or the like. Such gains can extend line of site (LOS) ranges to several km.
Remove these ads by
Signing UpStep 1Inbuilt laptop WiFi may only be useful with strong nearby APs
http://wireless.comxa.com/index.php/wireless-repeater
..I don't know about you guys, but for me UAWIFI UA3 usb adapter is the BEST.
No other adapter can compare to this baby, it is VERY powerful.
There are few people sell them on ebay, but I got mine directly from mft. website www.uawifi.com price is same.
I also know that it is Made in USA, so at least by buying it I am supporting US workers.
Some suggestions to this topic:
You can easily build your own parabolic dish with cardboard with glued tin foil on it. There's a diagram somewhere on the web, you only have to print it on a A4 paper, cut the cardboard following the lines, glue the tin foil and mount it on the router's antenna. It works nice, but I would use a wok for better durability. Also I would connect the ground wire from the usb cable to the dish. This improves the shielding.
Modifying the laptop's antenna is also an option like in:
http://www.instructables.com/id/Dell-Laptop-WI-FI-High-Gain-Antenna-Mod-Increase--1/
I'm looking for a circuit to measure signal strangth in the WiFi range, this would be nice to adjust the correct bearing of the dish. I'll let you know...
It really is necessary, I swear!
Just becuz I'm a nice guy!
Thanks
Danny
How to crack WEP encryption (wifi security)
How to break MAC filtering (wifi security)
The problem is getting the coverage for such a project for this to work. we need people and resources. People can also donate any amount of bandwidth to share on the network (i.e. 1gig or more?). Coverage could be overcome with the concept of WokFI as seen here http://www.usbwifi.orcon.net.nz/ I think these small ideas can be the building blocks of a free network without the extreme regulations of a professionally run network.
Auckland wide Wifi Network? anyone keen? or have ideas to expand on this?
