"Talk Box"
\"Talk Box\"
how to make a talk box, for almost noting (much better than the real ones that are $100+)
Step 1Parts
parts
Unforunatley i did not post tihs until i knew it worked... so that means that is was all packed up and i was unable to take it apart. sorry abput this but i hope you can use the diagram.
Parts:
foam craft ball(should be just a bit bigger than your speaker)
speaker(mine has about a 3in. diameter
Old broken guitar cable OR 1/4 in female jack
felt, foam, or something soft to dampen the sound
tube, 3-5ft. at about 1/4 in diameter
jar or box
hot glue
duct tape
16 comments
Aug 6, 2009. 7:10 AMayd203 says:
where do you solder the jack head onto the speaker???
Mar 9, 2009. 6:49 AMtiffanyrosesaucier says:
thnks, its better than buying one and it sounds so cool :) how did u learn to make this?
Jan 4, 2008. 9:57 PMGorillazMiko says:
Nice job, that first picture is pretty random, haha, cool Instructable. :-)
Mar 4, 2009. 3:16 PMheyzuphowsitgoin says:
The first picture is a talking box!
Mar 16, 2008. 1:50 PMbutthead95 says:
dude i used a funel instead works better u cant see funnel i put it in the speaker box backward and the cover over the back of speaker and alligator clips
Jan 19, 2008. 4:50 AMjasrv28 says:
sweet thanks. whats the purpose of the foam ball cutout as opposed to something more sturdy?
Dec 30, 2006. 6:17 PMJesus10555 says:
I made one today, its pretty sweet, Although it is a bit hard to talk with, but thats what practicing is for.... plus I only had a bigger tube lying around, so I couldnt follow the "1/4" size
Dec 24, 2006. 1:58 AMIbanezfoo says:
How does this actually sound? Got any clips? I tried making one of these a few years ago but it sounded like crap. I eventually just went and bought a Banshee.
Jul 18, 2006. 10:43 AM0.775volts says:
you just have to watch your power levels. i run tiny speakers like this off of professional power amplifiers all the time (we call them "practicals" on stage, like on a set we would have a clock radio, and would just wire up the speaker in it so we could play cues through it). just make sure your levels aren't too high. otherwise hexadecimal is correct, you'll fry your speakers, which could short and, in turn, fry your amp.
Jul 17, 2006. 10:01 PMhexedecimal99 says:
Maybe you should put a warning up or something, if you're gonna use the speaker out jack from an amp head, make sure that the resistance is right, if you hook up an 8 ohm speaker jack up to a 4 ohm speaker, be prepared for some fireworks
Jul 10, 2006. 1:50 PMSizzleBacon_12341 says:
interesting
Jul 9, 2006. 5:47 PMtrebuchet03 says:
Peter Frampton did this... A bud of mine made one, very simple and used a $5 megapgone from harbor freight. Didn't really use a box since the tube goes inside the cone and all - it was quite effective, a better/bigger megaphone would have made it easier though :P... In any case, its a very very cool sound if you can find a use for it... Just remember that the guitar is the driver... so no sound from guitar means you won't hear anything you say ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:admanrocks
my name is Adam!
