"TouchTimer" EggLight (valentine's gift)
\"TouchTimer\" EggLight (valentine\
Short description:
+High brightness microcontrolled LED light
+Touch Enabled (no buttons!) , the touch sensor will check it's inputs every 288ms to conserve power
+"Shutdown" TIMER : If the user holds the finger contacts for N seconds it will take N minutes for it to shutdown (or by touching it again )
+Estimated 60 days of battery life (15 min of use per day)
This is a Bedside Night Light I've built for my girlfriend:
+It had to be small
+Portable soft lighting for "stealth home navigation" at night
+It had to be COOL !
The Design:
ping-pong ball + generic_product_cap + capacitive_sensor_made_with_a_pic = EggLight !
Stuff needed :
- Ping-Pong ball
- Generic Product Cap
- PIC12F675 (any pic will do)
- A BC548 transistor (or similar)
- some standard resistor values: 100ohm , 1Kohm , 1Mohm
- 10000mcd led (When I have time I'll do the RGB version ;-)
- 2 CR2032 (button cell)
Step 1The Design
The Design
The initial design was supposed to be like the first picture... but an hiperbolic surface isn't quite easy to DIY =/
So I switched to the EggFormat
By placing the batteries on the lower side of the cap and sanding a piece of it it will stand-up straight
12 comments
Feb 16, 2009. 10:29 AMesplonky says:
i'm obsessed with the beatles!
Nov 10, 2008. 1:13 AMrac83 says:
Hy First, great project ;-) You used the CCS compiler right? I'm just trying to rewrite the code to SDCC but I'm little bit hanging in the air because this is my first attemp to program a PIC. Does someone here have some example codes for SDCC just to see how to make the skeleton and using I/O Pins...???
Aug 10, 2008. 6:58 PMGorillazMiko says:
Cool, but too hard for me! :P
Jan 4, 2008. 9:58 AMShifrin says:
This is cool! but can you find a clearer video?
Jan 4, 2008. 7:54 PMShifrin says:
Great! Thanks!
Apr 17, 2007. 7:55 PMMyrddin says:
How about a good image here, OK?? This ones crappy...
Feb 14, 2007. 10:07 PMdaenris says:
So how did you manage to make the contacts on the plastic?
Feb 14, 2007. 10:07 PMT3h_Muffinator says:
AWESOME! Although, you get -1 man point for getting pushed around from your girlfriend, but +10 man points for actually having a girlfriend..... Man, it's Valentine's day and I don't have anyone... sigh.....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Proteus
Engineer graduated @ poli.usp.br , Embedded Software Engineer @ v2com.mobi , and all around nice guy =]
