$1 Ipod To Stereo Connection
 by leevonk
For some reason people are surprised when I tell them this, so I decided I'd post it for all. This works for anything that has a headphone jack (e.g. laptop or desktop computer, cell phone, walkman, etc).
You just have to buy a $1 cable from a dollar store.
Picture 1
Plug one end into your ipod's earphone jack, the other end into your stereo's "aux in" or "video aux in" jacks (red and white).
Pictures 2 and 3
Then click your stereo buttons to put it into "aux mode" and press play on your ipod.
Picture 4
Done.
te101 says: Apr 29, 2012. 2:28 PM
thank UUUUUUUUUUUUUU
Feature Comment
djmelton9 says: Jan 8, 2010. 6:32 PM
Sorry but this is not an "Instructable"...This is just saying go buy the cable.
Feature Comment
Capt. Fat says: Mar 31, 2009. 2:52 PM
What if you have a micro stereo with no video aux
Feature Comment
gernboken in reply to Capt. FatJul 16, 2009. 1:35 AM
this
Capt. Fat in reply to gernbokenJul 17, 2009. 9:07 AM
huh?
pancho del rancho in reply to Capt. FatOct 11, 2009. 8:12 AM
do u have a mp3 line on the stereo
Capt. Fat in reply to pancho del ranchoOct 15, 2009. 11:54 AM
no, micro stereos don't have them ports on them
guitarman63mm says: Jun 26, 2008. 10:04 PM
Good lord. You need to learn a thing or two about a thing called impedance. This is why you shouldn't dabble in electronics if you don't have a clue about it.
Feature Comment
leevonk in reply to guitarman63mmJun 27, 2008. 6:34 AM
are you talking to me? I trust no
guitarman63mm in reply to leevonkJul 16, 2008. 8:57 PM
I was referring to people who plug any electronic device into their instrument's amplifier. It's not meant for that kind of load.
leevonk in reply to guitarman63mmJul 16, 2008. 9:23 PM
_what isn't made for _what kind of load? what's the 'instrument' your talking about? are you on drugs?
guitarman63mm in reply to leevonkJul 16, 2008. 10:54 PM
Looks like my statement does apply to you!
http://en.wikipedia.org/wiki/Electrical_load
There are quite a few people out there who are using this simple jack to play their music NOT through their auxilary stereo input, but rather an input jack on an amplifier (I've seen more than one supporting this usage on a guitar amplifier) I was just clarifying that point, as it can destroy expensive equipment.
As for that last bit, I'm sober, as of right now.
gernboken in reply to guitarman63mmJul 16, 2009. 1:38 AM
your comment is old but you seem like you know what you're talking about, so i hope you see it and respond. can you point me in the right direction to figure out how to make a jack to connect my ipod to my car stereo, which as far as i know doesn't have any sort of external input jack? i think i can buy the connectors to connect another stereo to my car's speakers, and i imagine i can buy or rig up a splitter, but i don't know how to connect my ipod to that jack without messing up my car speakers or my ipod.
guitarman63mm in reply to gernbokenJul 16, 2009. 10:52 AM
True, it is old. In reality, I'm just a guy with an interest in electronics, but I do happen to know a bit (more than the o/p and the 12-year-old kids that post on here, at least). Unless you have a newer car, the chances of you having an auxiliary jack in your vehicle are pretty slim. This limits your choice to essentially two options. One is a common cassette tape adapter that you simply plug in, and will run you about $20 US. The other is a wireless one that plugs into you you cigarette lighter, and changes a specific frequency to whatever it chooses (say, 88.7 is your ipod). Then you simply tune to that. Probably $20. Good luck.
baneat in reply to guitarman63mmDec 8, 2008. 3:32 PM
It sounds so bad that noone really would use it anyway, luckily.
leevonk in reply to guitarman63mmJul 17, 2008. 5:36 AM
electric guitars can output over 1V from their pickups, so if you don't turn the volume up on your ipod should be fine (to keep the ipod output well below it's 5v max). Even if you turn the ipod volume up all the way (so that the loudest music causes 5V output) should be ok as each of those 5v pulses are very short (just the very short crest(s) of a sinusoidal sound wave). I agree there is a possibility (although slight) of damaging your guitar amp if you're using it in that way.
guitarman63mm in reply to leevonkDec 8, 2008. 7:39 PM
It's not about voltage, it's about the impedance. Very big difference.
leevonk in reply to guitarman63mmJan 8, 2010. 9:29 PM
actually V=IR   and impedance is closely related to resistance, so it is indeed about voltage too. So the fact that ipods can vary their voltage output (by adjusting volume), should matter. This webpage (http://hyperphysics.phy-astr.gsu.edu/hbase/audio/imped.html) seems to corroborate this and mentions that in addition, modern amplifiers solve most problems of impedance matching. Is your background in electrical guitar use? Cause as far as I know their voltage output ranges can't be adjusted, also I'm not sure on how much current they are capable of outputting,..
7654321 in reply to leevonkMar 21, 2011. 8:16 PM
V=IR means voltage = current times resistance (I in this case stands for current not impendance)
leevonk in reply to leevonkJan 8, 2010. 9:31 PM
btw, I'm not trying to argue, I'm actually interested in this and making sure we both understand it fully in the end
bduffman says: Jul 14, 2007. 10:49 PM
hay when i saw this i remember i have one of these but it has a video cord also ( dose not work into my tv but dose into my sterio ) tryed it with my laptop as my ipod is flat
Feature Comment
othertonywilson in reply to bduffmanFeb 22, 2008. 9:43 AM
You need to use the yellow instead of the red... Apple tried to prevent people from playing movies on their television with out their special cord. So they switched the red and yellow on the headphone jack... I think someone should do an instructable on that. I would, but I no longer have an iPod capable of playing video.
baneat in reply to othertonywilsonDec 8, 2008. 3:33 PM
The most stupid marketing scheme, ever. seriously, switching the colours? HAH!
van johnson112 in reply to baneatMay 16, 2009. 6:38 PM
your right but they got me...i bought the cable hahaha
baneat says: Dec 8, 2008. 3:31 PM
I recommend getting a higher quality cable than this. It's just a 3.5mm stereo to LR phono. Belkin do a good one so do JVC. This is good too for a quick fix but for something more durable you want better.
Feature Comment
MonkaySquad says: Nov 1, 2008. 11:08 AM
Yes! People have no idea, but the dollar store has GREAT things cheap! Not only do they have the cord this poster shown, they also have one that has the (red/white) audio cord -- and the other end has a hole for stereo jack - headphone jack, which the dollar might sell as well. The process is almost the same, I do it all the time.
I hook up mine to my stereo receiver and blast my ipod music on it =D
Feature Comment
theRIAA says: Oct 5, 2006. 4:43 PM
aww does it only work with ipods...
Feature Comment
Suicide_Mouse in reply to theRIAASep 22, 2008. 3:38 PM
No, this will/should work with any MP3 player.
bduffman says: Feb 23, 2008. 12:34 AM
yea thats all well and good peoples but im wanting to no how to conect my ipod video 30gig to my tv and watch wats on my screen how do i go bout doing that i have the ssame cord as him but has a video bit also but dose the ipod video work out of the audio jack or will i need to mod a iput for the bottem of the ipod
Feature Comment
joejc in reply to bduffmanAug 14, 2008. 1:15 AM
Get a video plug like for a video camera and connect the camera end to the Ipod and other end to tv (i think you need to put them in a weird order, just Google it) or buy the one apple made for like $30
Sandisk1duo says: Jun 26, 2008. 10:44 PM
just don't charge your ipod/computer/whatever while your connected to the amp you might short it out (either the amp or ipod) this has not happened to my yet but it is a thing to watch for
Feature Comment
rockybob300 says: Jun 10, 2008. 7:51 AM
I tried this and it worked ;-)
Feature Comment
proffesor cuddles says: Mar 24, 2008. 4:01 AM
THANK YOU SO MUCH!!!!!!!!
Feature Comment
nascarwizard says: Mar 4, 2008. 6:13 PM
You my friend are a genius.
Feature Comment
csshih says: Feb 21, 2008. 2:54 PM
lol. Some stereo systems don't have an aux in.
Feature Comment
connorcancount! in reply to csshihFeb 21, 2008. 8:31 PM
if they are that old, they usually have a tape player, and you can find cheap tape cassette converters that look like a cassette with a headphone jack coming from it. thats what i use for my old ghettoized stereo!
rbhays says: Oct 5, 2006. 2:10 PM
no offense but isnt this kinda common sense?
Feature Comment
Korey in reply to rbhaysJan 16, 2008. 10:49 AM
You would be surprised! I still laugh whenever i see someone spending hundreds of dollars on some stupid iPod dock that sounds like crap because they think it's the only way to listen to their iPod without headphones.
theduke2011 in reply to rbhaysJan 8, 2008. 3:03 PM
unless you are to cautious at "messing things up" and never tried plugging things into A/V jacks, i to, believe it to be common sense, and to theRIAA, it works with anything that has a headphone jack as told above, and i think iPods are overrated, they are basically another mp3/media player that just has a fancy name, they're nice and all, but are not "All That", there are many others, just like them
baneat in reply to theduke2011Dec 8, 2008. 3:34 PM
Just wondering, what exactly did you want your mp3 player to do except play MP3s? kind of strange for people to expect otherwise.
barry505 says: Oct 6, 2006. 9:22 PM
Anyone that's too stupid to figure this out for themself, doesn't deserve to know.
Feature Comment
stncilr in reply to barry505Nov 30, 2007. 4:51 PM
kudos!
Swert in reply to barry505Jun 14, 2007. 6:37 PM
I have known about this for a while but didn't know that the cords could be found at the local dollar store, i just always went to the garage to get mine. (I don't know why we have them but we do).
inahurry in reply to barry505Feb 25, 2007. 10:51 AM
No one knows everything. Sometimes it's nice to let someone else figure out problems when you have other more pressing problems.
plzspoilme25 in reply to inahurryMar 7, 2008. 11:13 PM
yes indeed, kinna the whole point for this type of site......but i agreed with ikarias too...its kinna nice for ppl to think i'm a genius for doing something so simple and "comon sense to most of us" I'm a left brain thinker tho.....so i miss some simple things on the other side of the realm......i can think the whole thing out and draw the perfect blue print....but i have 4 project here that should be simple...in my head it is....so why are they not done.....so maybe i should pack up all my supplies ship them to u u can assemble them and ship back....LOL
ikarias in reply to barry505Oct 7, 2006. 2:05 AM
I dont agree. As long as there are "Less knowlageble" people in the word, the smarter we look. A lot of people think im brilliant when i show them [windows+d] to minimize all windows for instance. Or, when it comes to work, people love me when i explain the function of an (dont know the english word) aardlekschakelaar. (the switch that pops in in your fuse-box then a faulty device connects top earth). As long as there are stupid people in the world, we look smart.
leevonk in reply to ikariasOct 7, 2006. 11:12 AM
I didn't know the windows+d thing, that's nice, I always just click on the little desktop icon next to the start button which does the same thing.
Tool Using Animal in reply to ikariasOct 7, 2006. 8:24 AM
In english it a "breaker", still I think people just put "Ipod" in their titles to boost page views from the hipster doofus crowd.
fryrbird says: Jan 16, 2007. 8:06 PM
Why do they call it common sense when it isn't very common?
Feature Comment
remyzero7 in reply to fryrbirdJan 31, 2007. 12:40 AM
"they" are positive thinkers. wishful thinking? clearly.
duct tape in reply to fryrbirdJan 22, 2007. 9:26 PM
really....
fryrbird says: Jan 16, 2007. 8:09 PM
An amplified computer speaker set whith a subwoofer works very good plugged in my pod.
Feature Comment
mantislee says: Oct 5, 2006. 12:50 PM
Works well in after market car stereos also for crystal clear quality. Only drawback is that I can't stand the static and interference when I have to use my FM transmitter in a different car.
Feature Comment
ikarias in reply to mantisleeOct 5, 2006. 1:44 PM
Mantislee, have you tried better quality caples? Gold for instance? It can make a lot of difference.
Jrabbit05 in reply to ikariasOct 22, 2006. 6:46 PM
Don't be fooled, silver is a better conductor.
mikecheng says: Oct 21, 2006. 11:11 PM
the infamous Y-wire.
Feature Comment
VIRON says: Oct 8, 2006. 2:28 AM
Ipods are really lame compared to walkmans.
Feature Comment
irollmyown in reply to VIRONOct 10, 2006. 6:35 PM
ha, walkmans were pretty badass. i just found my the other day and it brought back some good memories
ikarias in reply to VIRONOct 8, 2006. 11:18 AM
Wow. i didnt even know walkmans still existed. I mean, a protable cassette player. damn. Second: the reason the ipod is all but lame, is because, if you have one, youre a little more "the man" then those who dont have one. So, per definition, it is the exact opposite. (and no, i dont own an ipod, the company, or have shares in it )
vader406 in reply to ikariasDec 13, 2007. 8:15 PM
Walkmans are still going strong with the new eriksson phones. ;0
Unforgiven_God says: Oct 5, 2006. 8:27 PM
hey said you can connect anything to ur stereo with this method...not just ipods
Feature Comment
leevonk in reply to Unforgiven_GodOct 6, 2006. 5:34 AM
yeah, I added that after he asked that question to make him look dumb, heheh
leevonk says: Oct 5, 2006. 3:40 PM
you can connect anything to your stereo with this method. it is common sense if you know that the stereo has an aux-in, but every friend that I have mentioned this to is all surprised. I think a lot of people think that since there are all those specialized 'ipod dock stereos' that you can't connect it to a normal stereo.
Feature Comment
xrobevansx in reply to leevonkOct 5, 2006. 7:27 PM
this is because younger people tend to have no "logic" or "critical thinking" skills. It's not really their fault. Everything to them is done fore them and instantly: on demand video, internet, etc. They don't have to "think" anymore or have common sense.
leevonk in reply to xrobevansxOct 6, 2006. 5:33 AM
I'm 25
trebuchet03 says: Oct 5, 2006. 2:17 PM
Meh... I lost you at "buy...." and I don't see how it's a modification... In any case, this is how I connect my laptop to my stereo :P
Feature Comment
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
