The hardest part for me was locating the M4 machine screws that will fit the standard 100x200 VESA mount of the TV. Every hardware store I checked around me only carried the SAE screw thread patterns.
I lucked out last week and finally found my screws in an IKEA KOSING (200.512.01) drawer pulls for $2. I took a chance on it having the right screws since I didn't carry a caliper with me and the package did not specify the screw size. It came with 24 screws 12 each in 3/4-inch and 1-inch sizes so my pulls still have a complete set of screws after this project.
Other materials needed was two 2x4x8 that I had left over from another project. Always good to have them around. A 6x10-inch piece of half-inch plywood (1 inch of material around the 100x200mm mount which translate to around 4x8 inches). A number of 8x3-inch drywall screws to attach everything together. Six washers - I don't know the exact size but it measures 11/16-inch outside diameter and 1/4-inch inside diameter.
Remove these ads by
Signing UpStep 1The 100x200 VESA mount from plywood
I used a little nail to drive into those six cross lines and remove it to help start my drilling. I used a 5/32-inch drill bit to drill the six holes for the mount. I dry fitted them to the back of the TV with the 1-inch screws to make sure they were correct. I had to widen 1 of the holes and it went on beautifully.
First off get an inexpensive, made for the set wallmount. TARGET has the ones that simply tilt for around $65 and the flexible ones (right, left; in, out; no up down) for around $100.
THE SET IS NOW OFF THE FLOOR, IT IS SAFE, AS ARE YOU!
Second, as you are handling the mounting hardware, attaching it to the TV, before you mount it to the wall, try to judge the balance.
The object here is to find an old industrial fan base or the like, 50# or so, to attach two square steel tubes to, perhaps a casting in cement in an oil sump pan. These tubes would ultimately attach to the bracket you previously attached to the set.
HERE'S THE CAVEAT: The r*e*a*l stands are crap and too expensive but they are safe. Mount it to the wall first, live with it. If you hate it you can always use the bracket for your nefarious plans later. I will draw you up something, not expensive, not overly ugly. Just promise to give the wall first crack!
Tom Randol tomran047@sbcglobal.net "God, please save me from your followers!" - Bumper Sticker "Fill what's empty, empty what's full, and scratch where it itches." - the Duchess of Windsor>
