3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
$10 LCD TV Floor Stand
I have a 32-inch LCD TV that needed a custom stand to mount it at the foot of my bed as I don't have the room for a normal TV stand.
The hardest part for me was locating the M4 machine screws that will fit the standard 100x200 VESA mount of the TV. Every hardware store I checked around me only carried the SAE screw thread patterns.
I lucked out last week and finally found my screws in an IKEA KOSING (200.512.01) drawer pulls for $2. I took a chance on it having the right screws since I didn't carry a caliper with me and the package did not specify the screw size. It came with 24 screws 12 each in 3/4-inch and 1-inch sizes so my pulls still have a complete set of screws after this project.
Other materials needed was two 2x4x8 that I had left over from another project. Always good to have them around. A 6x10-inch piece of half-inch plywood (1 inch of material around the 100x200mm mount which translate to around 4x8 inches). A number of 8x3-inch drywall screws to attach everything together. Six washers - I don't know the exact size but it measures 11/16-inch outside diameter and 1/4-inch inside diameter.
Step 1The 100x200 VESA mount from plywood
Using a speed square I drew a center line 1 inch in from one of the long (must be straight) edge -- I marked this edge and used it to measure all the others lines from here -- Very Important to note this in case your 6x10 piece of plywood is not squared off as mine was not (that's what happen with scrap wood). Then I measured 100 mm and drew the second center line parallel to the first. Draw a center line 1 inch in from the short side with the speed square along the reference edge I marked earlier. Measured 100 mm from there and draw corresponding center line. Measured 100 mm from this line and draw the last center line. Where all these 5 center lines meet are the required holes for the 100x200 mount. Using a caliper and speed square I checked all center lines to make sure they are the right dimensions.
I used a little nail to drive into those six cross lines and remove it to help start my drilling. I used a 5/32-inch drill bit to drill the six holes for the mount. I dry fitted them to the back of the TV with the 1-inch screws to make sure they were correct. I had to widen 1 of the holes and it went on beautifully.
7 comments
Jan 13, 2012. 5:07 PMpizz says:
This is a nice design. Only thing id add is a swivel hinge. Also make it out of oak wood so its more sturdy.
Dec 4, 2011. 7:08 PMKyrocken says:
I was in need of a cheap stand to get my 32" LCD off the ground. I made a very similar stand from your plans here. I only spent $8 on wood and $5 on wood glue. Very economical and utilitarian :P. Thanks!
Aug 26, 2010. 9:25 PMclaudiapatx says:
This is great. I have a 22inch monitor I picked up at a garage sale for $3 with no stand. This will work great! Thanks so much for a beautifully simple solution!
May 27, 2010. 1:07 PMtomran says:
I tell you, if space is an issue:
First off get an inexpensive, made for the set wallmount. TARGET has the ones that simply tilt for around $65 and the flexible ones (right, left; in, out; no up down) for around $100.
THE SET IS NOW OFF THE FLOOR, IT IS SAFE, AS ARE YOU!
Second, as you are handling the mounting hardware, attaching it to the TV, before you mount it to the wall, try to judge the balance.
The object here is to find an old industrial fan base or the like, 50# or so, to attach two square steel tubes to, perhaps a casting in cement in an oil sump pan. These tubes would ultimately attach to the bracket you previously attached to the set.
HERE'S THE CAVEAT: The r*e*a*l stands are crap and too expensive but they are safe. Mount it to the wall first, live with it. If you hate it you can always use the bracket for your nefarious plans later. I will draw you up something, not expensive, not  overly ugly. Just promise to give the wall first crack!
Tom Randol tomran047@sbcglobal.net "God, please save me from your followers!" - Bumper Sticker "Fill what's empty, empty what's full, and scratch where it itches." - the Duchess of Windsor>
Feb 26, 2009. 2:11 PMplzspoilme25 says:
what do u think about trying this type of stand for a 50". long story to the how and y i have a 50" for my bed room but hey sometimes we need to spoil or be spoiled...problem a: it was a display model so no stand or bracket or anything to stand it up. problem b: like u space is an issue, i got the tv same time i got a new king bed...which have yet to find platform bed i like(or are able to build) so looking for ideas for the tv stand....even the cheapest one at local stores concern me about stablity on that big of a tv. thanks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Hieu
