Introduction: $100 Super Bright Flashlight for Under $10!
Let me say right up front that inspiration for this Instructable is credited to dchall8 for his Tactical Flashlight Instructable. I thought there had to be an easier way to mod a smaller flashlight with less hardware and one that took less time. I put this one to the test against my Surefire E2 that cost $95.
Watch the video for Test Results! You will be suprised!
Step 1: Here Is All You Need...
1. Eveready Contractor Industrial Flashlight
Model #IN215WB-S. These are impact-resistant with a heavy-duty casing that withstands a 5-foot drop test on concrete. Resistant to grease, oil, gasoline and solvents. Shock- and corrosion-resistant.
Step 2: Item #2
Step 3: Item #3
One (1) Radio Shack KPR112 Krypton Flashlight Bulb
Step 4: Last Item
5/8" Drill Bit or file.
Step 5: EZ Steps...
1. Disassemble the flashlight, removing the AA batteries (if installed) and factory lamp. Unscrew the top and then unscrew the small lamp housing to get to the lamp.
2. Install the Radio Shack lamp and re-assemble the housing
3. Drill or file down the ridges inside the flashlight to make room for the 123 batteries
4. Install the 3 Lithium Ion batteries and screw on the bottom.
5. Turn it on!
(Optional: I painted mine black satin to make it look like the real thing...and it IS!)
Here is the video of the whole project along with Test Results! Enjoy!
5. Turn it on!
