$11 Super Wide Angle Digital Camera by slacy
Add a 160 degree wide angle lens to your existing digital camera for $11. This was based on ideas from the following webpage: http://aggregate.org/DIT/peepfish/
Step 1: Go to your favorite hardware store, and buy a wide angle door viewer.
You should be able to find one of these at any hardware store. I got mine at Home Depot for about $11. The key attributes that you're looking for is the largest possible "eye hole". There are a bunch of these door viewers that have very small openings, and they won't produce a very good image. Get the one I'm showing here, and it will work great. The opening is just about the size of the lens on my old Canon S230.
1-40 of 62Next »
Technomage says: Dec 4, 2006. 1:19 PM
I tried this over the weekend. It works great. I used the idea on my 300D SLR.
As there was a lot of bright lights I got a ton of flaring. Check out some of the pictures below.
There are good SLR instructions here. Short version below:
I had drilled a hole in a 55mm lens cap ($4.95)
I used the same peephole from homedepot and hot glued it to the lens cap. ($7.50 and $1)
I attached the lenscap to my 28-90 Sigma lens (it has macro)
Pictures where best around 50-70 mm not in macro mode and with manual focus
Done.
This was my first instructable project!
RUMCYCO says: Oct 7, 2011. 1:12 AM
Nice work mate ;)
Ninzerbean says: Oct 1, 2009. 5:15 AM
I went to your link - these speak to me also! They are really cool - use them for the art work on CD's - you can buy round labels for them, glossy is best. Wonderful!
poetapex says: Jan 31, 2009. 5:14 PM
Hey good job.
PetervG says: Apr 26, 2008. 4:35 AM
Okay so how do I do this...
Ghost Wolf says: Jan 17, 2011. 12:51 AM
LAME! Check out mine! It's bigger than yours lol
maito says: Jan 11, 2011. 3:16 AM
ZAS! en toda la boca
http://www.geeky-gadgets.com/diy-fish-eye-lense-19-11-2009/
Ghost Wolf says: Jan 17, 2011. 12:52 AM
Translation: ZAP! whole mouth
Phoghat says: Aug 18, 2008. 6:10 AM
In the OLD days, we would find an extra lens cap and cut a hole in the center big enough to hold the door viewer. Just snap it on and you're good to go.
jenniec says: May 29, 2008. 12:00 PM
it goes on your stock lens - i have the canon Xti - and it works awesome.
way less of a risk ahah just buy this
PetervG says: May 29, 2008. 12:37 PM
The door viewer wont fit on a DSLR..
linuxrules says: Aug 27, 2010. 11:46 PM
Hey bud, take a look at this image: http://duolian.smugmug.com/Other/Faux-Fisheye/gear/14344129_JjoU6-O.jpg
Pepealej says: Dec 26, 2010. 9:44 AM
Zoom in
buffysissy1 says: Oct 13, 2010. 2:03 AM
I also tried this with a point and shoot but epoxied another lens on top, a lens I got out of a cheap "panoramic camera", just epoxied the edges and got a nice effect. Will post pix soon.
buffysissy1 says: Oct 13, 2010. 2:01 AM
The large door viewer seems the way to go with these projects.
mg0930mg says: Oct 10, 2010. 7:17 PM
http://www.youtube.com/watch?v=AB7rnAY55UM
Thanks!
Funguystuff says: Sep 24, 2010. 8:17 AM
thanks for this instructable man, i knnew that saving this door "eye" would help me someday, and now i did. you should add to the key words of this intstructable "skate" because this is how sk8 videos are shot and that was what i was looking for.
Gr8 Instructable!
yerfdog123 says: Jun 10, 2010. 6:41 AM
my camera has a square shaped around the lens, will this still work?
mista.v says: Nov 21, 2009. 8:04 AM
You know, if you measure out the DoF properly, you won't need to crop this bit out.
sjoobbani says: Dec 31, 2009. 8:43 PM
you should use some kinda tube, and maybe some tape, without using the sticky side on your cam. to make it removable.
tommyskate says: Jun 7, 2009. 11:22 PM
iv got this yes video camera its a mini camera wat do i no and i want one for my skating
Scottishsamurai_545 says: Aug 7, 2008. 11:29 AM
I found your project a couple weeks ago, linking off a DIY kaleidoscope lens project. Most of the time I work with a full-size camera, and had never really thought of using a door viewer with the lens on a small camera. I gave your project a try with a cheap point & shoot I have, and the results were impressive. I then figured out a way of using a piece of plumbing hardware to adapt the viewer to my bridge camera, which doesn't do too bad of a job of making fish-eye pictures. Good work!
say88got says: Jul 2, 2008. 12:29 PM
hey do any of u now how to make one wit out a peephole
oldbastardjoe says: Jan 24, 2008. 10:39 AM
i made one but i sawwed off some excess so i wouldnt have to zoom as much. if you do the same make sure no glass gets cut as o my first attempt i cut the eye glass and it doesnt work.
bowmaster says: Oct 22, 2007. 8:14 AM
If you could find a 180 degree door viewer you would have a fish eye lens
Trebawa says: Jan 21, 2008. 3:20 PM
At Home Depot they have 200° viers right next to the 160° ones. I got one and will post pictures soon.
Runeshai says: Jan 2, 2008. 8:51 PM
That's pretty sweet. Is there a way you could make them the regular rectangle photo shape, instead of the circle, or would that be too hard to do in-camera with this rig?
inquisitive says: Oct 21, 2007. 9:29 PM
Lovely pictures! Your cats are so cute! The coloring on one looks like split bangs and the other one seems to have an eye patch-this will be fun to play with. Thanks!
X_D_3_M_1 says: Oct 19, 2007. 5:57 PM
kool kat. hes so cute
dimockn says: Jun 24, 2006. 8:16 PM
Used Nero PhotoSnap to correct the distortion as shown. Takes away some of the charm ? :)
wide-angle_using_door_peep-hole_viewer.jpgwide-angle_using_door_peep-hole_viewer_with_barrel_distortion_corrected.jpg
locofocos says: Apr 20, 2007. 3:06 PM
Could you tell me how to do that? I know how to do the thing where you take a picture of a flat surface at an angle, the use the proportion/crop function and it looks straight, but how would you do that with this?
JamesRPatrick says: Oct 19, 2007. 5:38 PM
N-Game!
eyballer9 says: Jun 16, 2007. 2:57 PM
its a wide angle or a fish eye lense you can get them for all kinds of cameras it makes the shot wider
locofocos says: Jun 17, 2007. 7:02 PM
I know that, but can you use Photoshop to take the round, wide-angle pictures and turn them into normal square ones (like shown above)?
Sidney Floyd says: Feb 1, 2007. 3:39 AM
definitley the first looks so much cooler whats the point of a wide angle lenseif theres no hokey ring of distortion?
slacy (author) says: Jun 26, 2006. 8:31 PM
The reason this doesn't look as interesting as you might expect is that all the objects in frame are too far from the camera. Take a skew-angle close-up picture and correct that. I think you'll get a much better feel for how weird things get. BTW, if the purpose of PhotoSnap is to stitch panoramas, then you'd expect it to look "normal" wouldn't you?
zwild1 says: Mar 4, 2007. 1:34 PM
If you remove the barrel on the fisheye, (hacksaw) you no longer have to worry about the "tunnel vision"
iman says: Jun 12, 2006. 11:44 AM
i like your cat lol
slacy (author) says: Jun 26, 2006. 8:32 PM
Thanks! She's word renouned now! (BTW, my gallery actually has pictures of 2 different cats. Can you tell them apart?)
Bob7k says: Feb 9, 2007. 6:27 PM
hahaa, cats are awesome! i have 2 cats, hamsters and a pair of rats, im a pet freak, but then again, care is split up over 6 people, but only i care for the hamsters and rats
1-40 of 62Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
