$11 Super Wide Angle Digital Camera
 by slacy
Add a 160 degree wide angle lens to your existing digital camera for $11. This was based on ideas from the following webpage: http://aggregate.org/DIT/peepfish/
Step 1: Go to your favorite hardware store, and buy a wide angle door viewer.
You should be able to find one of these at any hardware store. I got mine at Home Depot for about $11. The key attributes that you're looking for is the largest possible "eye hole". There are a bunch of these door viewers that have very small openings, and they won't produce a very good image. Get the one I'm showing here, and it will work great. The opening is just about the size of the lens on my old Canon S230.
Technomage says: Dec 4, 2006. 1:19 PM
I tried this over the weekend. It works great. I used the idea on my 300D SLR.
As there was a lot of bright lights I got a ton of flaring. Check out some of the pictures below.
There are good SLR instructions here. Short version below:
I had drilled a hole in a 55mm lens cap ($4.95)
I used the same peephole from homedepot and hot glued it to the lens cap. ($7.50 and $1)
I attached the lenscap to my 28-90 Sigma lens (it has macro)
Pictures where best around 50-70 mm not in macro mode and with manual focus
Done.
This was my first instructable project!
RUMCYCO in reply to TechnomageOct 7, 2011. 1:12 AM
Nice work mate ;)
Ninzerbean in reply to TechnomageOct 1, 2009. 5:15 AM
I went to your link - these speak to me also! They are really cool - use them for the art work on CD's - you can buy round labels for them, glossy is best. Wonderful!
poetapex in reply to TechnomageJan 31, 2009. 5:14 PM
Hey good job.
PetervG says: Apr 26, 2008. 4:35 AM
Okay so how do I do this...
Ghost Wolf in reply to PetervGJan 17, 2011. 12:51 AM
LAME! Check out mine! It's bigger than yours lol
maito in reply to PetervGJan 11, 2011. 3:16 AM
ZAS! en toda la boca
http://www.geeky-gadgets.com/diy-fish-eye-lense-19-11-2009/
Ghost Wolf in reply to maitoJan 17, 2011. 12:52 AM
Translation: ZAP! whole mouth
Phoghat in reply to PetervGAug 18, 2008. 6:10 AM
In the OLD days, we would find an extra lens cap and cut a hole in the center big enough to hold the door viewer. Just snap it on and you're good to go.
jenniec in reply to PetervGMay 29, 2008. 12:00 PM
it goes on your stock lens - i have the canon Xti - and it works awesome.
way less of a risk ahah just buy this
PetervG in reply to jenniecMay 29, 2008. 12:37 PM
The door viewer wont fit on a DSLR..
linuxrules in reply to PetervGAug 27, 2010. 11:46 PM
Hey bud, take a look at this image: http://duolian.smugmug.com/Other/Faux-Fisheye/gear/14344129_JjoU6-O.jpg
Pepealej says: Dec 26, 2010. 9:44 AM
Zoom in
buffysissy1 says: Oct 13, 2010. 2:03 AM
I also tried this with a point and shoot but epoxied another lens on top, a lens I got out of a cheap "panoramic camera", just epoxied the edges and got a nice effect. Will post pix soon.
buffysissy1 says: Oct 13, 2010. 2:01 AM
The large door viewer seems the way to go with these projects.
mg0930mg says: Oct 10, 2010. 7:17 PM
http://www.youtube.com/watch?v=AB7rnAY55UM
Thanks!
Funguystuff says: Sep 24, 2010. 8:17 AM
thanks for this instructable man, i knnew that saving this door "eye" would help me someday, and now i did. you should add to the key words of this intstructable "skate" because this is how sk8 videos are shot and that was what i was looking for.
Gr8 Instructable!
yerfdog123 says: Jun 10, 2010. 6:41 AM
my camera has a square shaped around the lens, will this still work?
mista.v says: Nov 21, 2009. 8:04 AM
You know, if you measure out the DoF properly, you won't need to crop this bit out.
sjoobbani in reply to mista.vDec 31, 2009. 8:43 PM
you should use some kinda tube, and maybe some tape, without using the sticky side on your cam. to make it removable.
tommyskate says: Jun 7, 2009. 11:22 PM
iv got this yes video camera its a mini camera wat do i no and i want one for my skating
Scottishsamurai_545 says: Aug 7, 2008. 11:29 AM
I found your project a couple weeks ago, linking off a DIY kaleidoscope lens project. Most of the time I work with a full-size camera, and had never really thought of using a door viewer with the lens on a small camera. I gave your project a try with a cheap point & shoot I have, and the results were impressive. I then figured out a way of using a piece of plumbing hardware to adapt the viewer to my bridge camera, which doesn't do too bad of a job of making fish-eye pictures. Good work!
say88got says: Jul 2, 2008. 12:29 PM
hey do any of u now how to make one wit out a peephole
oldbastardjoe says: Jan 24, 2008. 10:39 AM
i made one but i sawwed off some excess so i wouldnt have to zoom as much. if you do the same make sure no glass gets cut as o my first attempt i cut the eye glass and it doesnt work.
bowmaster says: Oct 22, 2007. 8:14 AM
If you could find a 180 degree door viewer you would have a fish eye lens
Trebawa in reply to bowmasterJan 21, 2008. 3:20 PM
At Home Depot they have 200° viers right next to the 160° ones. I got one and will post pictures soon.
Runeshai says: Jan 2, 2008. 8:51 PM
That's pretty sweet. Is there a way you could make them the regular rectangle photo shape, instead of the circle, or would that be too hard to do in-camera with this rig?
inquisitive says: Oct 21, 2007. 9:29 PM
Lovely pictures! Your cats are so cute! The coloring on one looks like split bangs and the other one seems to have an eye patch-this will be fun to play with. Thanks!
X_D_3_M_1 says: Oct 19, 2007. 5:57 PM
kool kat. hes so cute
dimockn says: Jun 24, 2006. 8:16 PM
Used Nero PhotoSnap to correct the distortion as shown. Takes away some of the charm ? :)
wide-angle_using_door_peep-hole_viewer.jpgwide-angle_using_door_peep-hole_viewer_with_barrel_distortion_corrected.jpg
locofocos in reply to dimocknApr 20, 2007. 3:06 PM
Could you tell me how to do that? I know how to do the thing where you take a picture of a flat surface at an angle, the use the proportion/crop function and it looks straight, but how would you do that with this?
JamesRPatrick in reply to locofocosOct 19, 2007. 5:38 PM
N-Game!
eyballer9 in reply to locofocosJun 16, 2007. 2:57 PM
its a wide angle or a fish eye lense you can get them for all kinds of cameras it makes the shot wider
locofocos in reply to eyballer9Jun 17, 2007. 7:02 PM
I know that, but can you use Photoshop to take the round, wide-angle pictures and turn them into normal square ones (like shown above)?
Sidney Floyd in reply to dimocknFeb 1, 2007. 3:39 AM
definitley the first looks so much cooler whats the point of a wide angle lenseif theres no hokey ring of distortion?
slacy (author) in reply to dimocknJun 26, 2006. 8:31 PM
The reason this doesn't look as interesting as you might expect is that all the objects in frame are too far from the camera. Take a skew-angle close-up picture and correct that. I think you'll get a much better feel for how weird things get. BTW, if the purpose of PhotoSnap is to stitch panoramas, then you'd expect it to look "normal" wouldn't you?
zwild1 says: Mar 4, 2007. 1:34 PM
If you remove the barrel on the fisheye, (hacksaw) you no longer have to worry about the "tunnel vision"
iman says: Jun 12, 2006. 11:44 AM
i like your cat lol
slacy (author) in reply to imanJun 26, 2006. 8:32 PM
Thanks! She's word renouned now! (BTW, my gallery actually has pictures of 2 different cats. Can you tell them apart?)
Bob7k in reply to slacyFeb 9, 2007. 6:27 PM
hahaa, cats are awesome! i have 2 cats, hamsters and a pair of rats, im a pet freak, but then again, care is split up over 6 people, but only i care for the hamsters and rats
MDude says: Oct 28, 2006. 5:57 PM
I like the look of the picture with the metal still there, it makes it look like it was taken through a port hole.
ian$½ says: Sep 29, 2006. 4:18 PM
it's pretty distorted.. is that the camera or the peephole? so you have any ideas for a bigger lens.. like a 52mm diagonal? still cool
sixcrows says: Aug 28, 2006. 4:02 PM
Can anybody tell me where I can find one of these door viewers. The only ones I've found (at Home Depot and Lowe's) are the ones with the very slender opening. Thanks.
baggers says: Aug 8, 2006. 1:11 PM
I've written up some instructions for using this technique on a camcorder here: http://www.camcorderinfo.com/content/Video-Tricks-Build-a-Cheap-Wide-Angle-Adapter.htm
heyster says: Jul 25, 2006. 2:42 AM
I have a sony cybershot dsc-p8. A camera about 3 years old but takes great pictures. I will certainly try this instuctable.
anntda says: Jul 11, 2006. 4:52 PM
Old or new idea, it's new to me & I'm anxious to try it out. I, too, have a Powershot. Did you need to do anything differently on this type of camera? Thanks for sharing!
amosslee says: Jun 25, 2006. 4:33 PM
I'm trying to build a physics demonstration device that has a fisheye lens in a globe (see photo or http://teacherresourceexchange.org/science/fisheye-lens-in-globe/). This hack works fine, but I need higher resolution. I'm looking at a miniature fisheye lens from sunex.com (mod dsl215), and trying to figure out how to get it attached to a camera. I opened up my web cam, but it doesn't have the right threading or mounting screws. I'm looking around at 1/3" CCD/CMOS cameras/chips, but companies don't seem to give specs on the threading of their lenses.
Anyone have any tips on how to match a "real" fisheye lens with a camera? The lens I'm looking at is rated as M12x0.5 threads, with two mounts available that have two 2.0 mm mounting holes 22 mm apart.
Ideally, I would attach the lens to a wireless camera, so when it is mounted inside the globe it can spin freely.
slacy (author) in reply to amossleeJun 26, 2006. 8:35 PM
I looked at your sample picture, and I don't understand why the sample image is so blurry -- did you remove the original lens optics? You'll need to keep the original optics in and just put the lens in front. For threaded adapters, take a look at the guy above who used a PVC fitting. That looks like it works really well, and would be pretty easy to do, I think. If you don't care about the webcam, just jam a bunch of silicone sealant or something similar to hold the lens in place. Careful with the optics though!
philbert says: Jun 21, 2006. 10:55 AM
I tried this with my camera... I shoot alot of video and tried a clip on wide angle and it just wasnt wide enough.... I use a mustek 3 in 1 dv5500 and a pop bottle top works great over the lens. I used a drill and just screwed in the doorviewer I shoot alot of skateboarding footage.. I LOVE the wide angle lens look.....but I dont have the money nor have the experience to operate a canon XL1 or anything of that nature, so I tried this and it works GREAT
slacy (author) in reply to philbertJun 26, 2006. 8:33 PM
Awesome! You should upload some of your videos to Google Video and post links here so we can see them!
Cristo says: Jun 20, 2006. 4:09 PM
This is a great idea! Any suggestions on how to create a mount for a Powershot A530 or similar sized camera? It would be great to be able to 'pop' it on and off quickly when needed.
stevecooley says: Jun 14, 2006. 7:54 PM
Wow, I have that exact same honeysuckle in my back.. yard... or whatever my townhouse has of a yard. You in the san jose area? My town's got that stuff _everywhere_.
RuTemple in reply to stevecooleyJun 15, 2006. 11:07 AM
That photo is of Jasmine, which grows everywhere and smells wonderful. Guess I'd better hop off to the hardware store and take a pic of some honeysuckle, then! Great idea for a lens.
tekisui says: Jun 14, 2006. 5:34 PM
I've been using a set up like this for a few months now, inspired by the same website. I used the top from a medicine bottle to fix the peep hole to my Sony's lens. Works pretty well for about 10 bucks total.
parasymboligist in reply to tekisuiJun 15, 2006. 6:52 AM
how big around is your cybershot lens? i have a dsc-p71, and i'd LOVE to try this. thanks.
sdamy says: Jun 15, 2006. 2:05 AM
fishcatcher says: Jun 12, 2006. 12:33 PM
--does this work for electric cameras? +also can u use this on my video gamera?
leevonk in reply to fishcatcherJun 12, 2006. 4:08 PM
as long as your camera accepts light from the outside world through some sort of hole,... yeah.
westfw says: Jun 11, 2006. 10:52 PM
I remember seeing this idea in Popular Photography about 30 years ago; they had you mount the viewer in a lense cap for easy application/removal. That doesn't mean it's not good INSTRUCTABLE material now; I'm particularly impressed with how well this interfaces to todays digital cameras. (30 years ago; no digital cameras, and an entire multi-user mainframe computer would probably has less memory than people use for a single picture today. Sigh; I fell old.)
trebuchet03 says: Jun 11, 2006. 5:47 PM
Didn't someone already post how to add a fish eye lens using a peep hole lens?? Maybe it was hackaday :P This also works (and is a very useful) on webcams - especially if you use it for security purposed ;)
slacy (author) in reply to trebuchet03Jun 11, 2006. 6:07 PM
I couldn't find one describing this, so I figured I'd do it... (yeah, I know its old news).
trebuchet03 in reply to slacyJun 11, 2006. 6:10 PM
Yep... it was hackaday :P No worries though - its still quite useful ;)
http://www.hackaday.com/entry/1234000793073646/
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
