3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
$11 Super Wide Angle Digital Camera
Add a 160 degree wide angle lens to your existing digital camera for $11. This was based on ideas from the following webpage: http://aggregate.org/DIT/peepfish/
Step 1Go to your favorite hardware store, and buy a wide angle door viewer.
You should be able to find one of these at any hardware store. I got mine at Home Depot for about $11. The key attributes that you're looking for is the largest possible "eye hole". There are a bunch of these door viewers that have very small openings, and they won't produce a very good image. Get the one I'm showing here, and it will work great. The opening is just about the size of the lens on my old Canon S230.
62 comments
1-40 of 62next »
Dec 4, 2006. 1:19 PMTechnomage says:
I tried this over the weekend. It works great. I used the idea on my 300D SLR.
As there was a lot of bright lights I got a ton of flaring. Check out some of the pictures below.
There are good SLR instructions here. Short version below:
I had drilled a hole in a 55mm lens cap ($4.95)
I used the same peephole from homedepot and hot glued it to the lens cap. ($7.50 and $1)
I attached the lenscap to my 28-90 Sigma lens (it has macro)
Pictures where best around 50-70 mm not in macro mode and with manual focus
Done.
This was my first instructable project!
Oct 7, 2011. 1:12 AMRUMCYCO says:
Nice work mate ;)
Oct 1, 2009. 5:15 AMNinzerbean says:
I went to your link - these speak to me also! They are really cool - use them for the art work on CD's - you can buy round labels for them, glossy is best. Wonderful!
Jan 31, 2009. 5:14 PMpoetapex says:
Hey good job.
Apr 26, 2008. 4:35 AMPetervG says:
Okay so how do I do this...
Jan 17, 2011. 12:51 AMGhost Wolf says:
LAME! Check out mine! It's bigger than yours lol
Jan 11, 2011. 3:16 AMmaito says:
ZAS! en toda la boca
http://www.geeky-gadgets.com/diy-fish-eye-lense-19-11-2009/
Jan 17, 2011. 12:52 AMGhost Wolf says:
Translation: ZAP! whole mouth
Aug 18, 2008. 6:10 AMPhoghat says:
In the OLD days, we would find an extra lens cap and cut a hole in the center big enough to hold the door viewer. Just snap it on and you're good to go.
May 29, 2008. 12:00 PMjenniec says:
it goes on your stock lens - i have the canon Xti - and it works awesome.
way less of a risk ahah just buy this
May 29, 2008. 12:37 PMPetervG says:
The door viewer wont fit on a DSLR..
Aug 27, 2010. 11:46 PMlinuxrules says:
Hey bud, take a look at this image: http://duolian.smugmug.com/Other/Faux-Fisheye/gear/14344129_JjoU6-O.jpg
Dec 26, 2010. 9:44 AMPepealej says:
Zoom in
Oct 13, 2010. 2:03 AMbuffysissy1 says:
I also tried this with a point and shoot but epoxied another lens on top, a lens I got out of a cheap "panoramic camera", just epoxied the edges and got a nice effect. Will post pix soon.
Oct 13, 2010. 2:01 AMbuffysissy1 says:
The large door viewer seems the way to go with these projects.
Oct 10, 2010. 7:17 PMmg0930mg says:
http://www.youtube.com/watch?v=AB7rnAY55UM
Thanks!
Sep 24, 2010. 8:17 AMFunguystuff says:
thanks for this instructable man, i knnew that saving this door "eye" would help me someday, and now i did. you should add to the key words of this intstructable "skate" because this is how sk8 videos are shot and that was what i was looking for.
Gr8 Instructable!
Jun 10, 2010. 6:41 AMyerfdog123 says:
my camera has a square shaped around the lens, will this still work?
Nov 21, 2009. 8:04 AMmista.v says:
You know, if you measure out the DoF properly, you won't need to crop this bit out.
Dec 31, 2009. 8:43 PMsjoobbani says:
you should use some kinda tube, and maybe some tape, without using the sticky side on your cam. to make it removable.
Jun 7, 2009. 11:22 PMtommyskate says:
iv got this yes video camera its a mini camera wat do i no and i want one for my skating
Aug 7, 2008. 11:29 AMScottishsamurai_545 says:
I found your project a couple weeks ago, linking off a DIY kaleidoscope lens project. Most of the time I work with a full-size camera, and had never really thought of using a door viewer with the lens on a small camera. I gave your project a try with a cheap point & shoot I have, and the results were impressive. I then figured out a way of using a piece of plumbing hardware to adapt the viewer to my bridge camera, which doesn't do too bad of a job of making fish-eye pictures. Good work!
Jul 2, 2008. 12:29 PMsay88got says:
hey do any of u now how to make one wit out a peephole
Jan 24, 2008. 10:39 AMoldbastardjoe says:
i made one but i sawwed off some excess so i wouldnt have to zoom as much. if you do the same make sure no glass gets cut as o my first attempt i cut the eye glass and it doesnt work.
Oct 22, 2007. 8:14 AMbowmaster says:
If you could find a 180 degree door viewer you would have a fish eye lens
Jan 21, 2008. 3:20 PMTrebawa says:
At Home Depot they have 200° viers right next to the 160° ones. I got one and will post pictures soon.
Jan 2, 2008. 8:51 PMRuneshai says:
That's pretty sweet. Is there a way you could make them the regular rectangle photo shape, instead of the circle, or would that be too hard to do in-camera with this rig?
Oct 21, 2007. 9:29 PMinquisitive says:
Lovely pictures! Your cats are so cute! The coloring on one looks like split bangs and the other one seems to have an eye patch-this will be fun to play with. Thanks!
Oct 19, 2007. 5:57 PMX_D_3_M_1 says:
kool kat. hes so cute
Jun 24, 2006. 8:16 PMdimockn says:
Used Nero PhotoSnap to correct the distortion as shown. Takes away some of the charm ? :)
Apr 20, 2007. 3:06 PMlocofocos says:
Could you tell me how to do that? I know how to do the thing where you take a picture of a flat surface at an angle, the use the proportion/crop function and it looks straight, but how would you do that with this?
Oct 19, 2007. 5:38 PMJamesRPatrick says:
N-Game!
Jun 16, 2007. 2:57 PMeyballer9 says:
its a wide angle or a fish eye lense you can get them for all kinds of cameras it makes the shot wider
Jun 17, 2007. 7:02 PMlocofocos says:
I know that, but can you use Photoshop to take the round, wide-angle pictures and turn them into normal square ones (like shown above)?
Feb 1, 2007. 3:39 AMSidney Floyd says:
definitley the first looks so much cooler whats the point of a wide angle lenseif theres no hokey ring of distortion?
Mar 4, 2007. 1:34 PMzwild1 says:
If you remove the barrel on the fisheye, (hacksaw) you no longer have to worry about the "tunnel vision"
Jun 12, 2006. 11:44 AMiman says:
i like your cat lol
Feb 9, 2007. 6:27 PMBob7k says:
hahaa, cats are awesome! i have 2 cats, hamsters and a pair of rats, im a pet freak, but then again, care is split up over 6 people, but only i care for the hamsters and rats
1-40 of 62next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:slacy
Visit my blog at http://slacy.com/blog
