3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
$30 High-Speed PCB Drill Press
Want super clean holes in your latest PCB? Want your PCB drill-bit's to last much longer? Tired of using your dremel as the drill press it clearly isn't? For around $30, you can build this simple PCB drill-press.
Step 1Planning / Materials
This started when we (me and some fellow modders / hackers) realized we wanted a simple high-quality PCB drill dress, but didn't want to pay $400+ for something that would only run at around 20,000 rpm. We also did not want to use the standard dremel drill-press for drilling PCB's as they tend to break bits fairly fast, and PCB drill bits can be expensive.
The solution that we arrived at was to use a Harbor-Freight Pneumatic 1/8" Micro Die Grinder, and attach it in-plane with a precision linear slide rail. The Micro Die Grinder runs at 56,000 RPM and has the 1/8" collet that I needed for the PCB drill-bits.
The keep the die-grinder in-plane with the rail, we decided to mount the linear rail to a self-centering drill-press jig.
The parts list:
1.5" Square Steel Tubing - Scrap from Around the Shop
56K RPM Micro Die-Grinder Drill - Harbor Freight - $10.00
- http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=47869
Self Centering Drill Press Jig - Harbor Freight - $6.00
- http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92046
THK Linear Slide Rail - $10.00
- Ebay, Search for "THK Slide" or "Linear Slide"
MDF for deck - Scrap from Around the Shop
MISC. Screws - Scrap from Around the Shop
Springs - Home Depot / Lowes - $5.00
74 comments
1-40 of 74next »
May 6, 2012. 12:35 AMZ.K. says:
Interesting project though the harborfreight links no longer work and if I look on line for a similar device it is very expensive. Still, this has given me some ideas. I will probably use 2x4s instead of steel tubing and use a rotory tool as it rotates quite fast. I saw a few advertised on Amazon as being able to rotate up to 30,000rpm which is close to what you are using and good enough for my use. As for the slide, I think I can make something out of non-threaded steel rods or a drawer slide. In any case, your project looks good.
Oct 21, 2011. 11:05 AMpfred2 says:
It is too bad Harbor Freight doesn't sell the mini press I bought off of them anymore. It was only $29.99 Plug it in and go.
Nov 6, 2009. 2:57 PMelectronicdude says:
Do you think a piece of angle iron would work in replace of the self centering jig? I am trying to save as much money as possible
Aug 22, 2010. 11:40 AMdagenius says:
You say it's 30$, but in reality, you also need to get an air compressor, and a welder, etc. This could end up costing many hundreds of dollars if you have nothing but the parts for the drill press. Call back when you have one that doesn't need to be welded, and runs off of electricity.
Aug 22, 2010. 11:38 AMdagenius says:
Jul 6, 2010. 10:46 AMbombmaker2 says:
To anyone who says $30 is not reasonable: It is actually because if you get Harbor Freight's coupons, the grinder is only $15 and the drill press rig will be $6. The linear rail will be about $10. That's $31 which is reasonable. I just got some stepper control stuff from one of my dad's friends so I only need to buy the two Harbor Freight items.
Jun 21, 2009. 8:14 PMbobbyrae says:
Nice idea for those that really NEED 56k rpm. But I'm looking at the links you gave and eBay listings, and quickly coming to the realization that the $30 target price is NOT achievable. The grinder is actually $25 (+$8 shipping). The LOWEST price on eBay for that slide is $10, yes, but shipping is another $7. And so when I think about all the costs and efforts here, it seems a lot smarter to just buy a used bench drill press off Craiglist for $50 - $100. Of course it will only do 3000 rpm...
Jan 27, 2010. 6:01 PMDavad says:
I've got one of those drill press that do a max of 3100 RPM. I haven't broken any bits yet but the quality of the holes is not the the best. The carbide bits others have spoken of are designed specifically for PCB drilling and are supposed to be use at 35,000 RPM minimum. The pneumatic drill/grinder is a cheap solution for a high speed drill.
However, I agree with your findings of the prices. This instructables must have been written 20 years ago when thing where cheaper.
Jan 4, 2010. 10:30 PMwildo says:
 Looks pretty awesome to me. I just bought a $45 dremel drill press, and ended up breaking 2 #71 drill bits. Pissed. The drill press is going back, and I will buy one of these linear slides. Nice instructable!
Nov 6, 2009. 2:54 PMelectronicdude says:
I am planning on building it, and I went on you tube to see if you had a video on how to make but you didn't. I was wondering if it was ok with you if I made a video on how to build it. I aske because I didn't know if you were planning on posting a video or not. If it is O.K. with you I would like to.
Jun 19, 2007. 8:52 AMtechnopenguin says:
Also you could add a potentiometer to adjust the speed, and have an LCD or digit display to show the RPM, with the help of a small circuit or a microcontroller.
Oct 4, 2009. 1:34 PMadnimo says:
unless it's a humongous pot you won't be able to do that, you'll need PWM to drive the speed of the motor.
Oct 3, 2009. 4:09 PMthowardtf1 says:
I buy all my carbide bits with .125 shank to drill FR4 pcb material. I use 'Drill Bit City' ( www.store.yahoo.com/drillcity ). They seem to be priced ok, but have availability of all bits I need. (#67 (.0320) 10 for $15.00 at my last order.
May 19, 2008. 7:24 AMF7 says:
Can you recommend a source for miniature drill bits with an 1/8 shaft, suitable for drilling PCBs? Fiberglas will dull a drill pretty fast...
Sep 5, 2009. 10:59 PMBlackice504 says:
this cost a lot more then normal drill bits but get Titainium drill set i managed to find a good one from the local $2.00 asian shop and it was $7.00aud and they must be real the deal the brand name is duramax yes to the Russians this will be a funny brand name.
Sep 5, 2009. 10:34 PMBlackice504 says:
very nice work looks like something you got off the shelf thank you so much for idea's. PS i love my air tools over electrical tools.
Feb 11, 2009. 5:55 AMDYLEGO says:
Just a simple question, not to be rude or anything, but is there a reason to have a specialized PCB drill press when you already have one? I think I see one in the backgound... :P I am wondering if this would be useful since I already have a drill press. DYLEGO
May 30, 2009. 4:00 AMtamakid says:
yea i thought that at school, we have a big drill press and then we have a smaller one for drilling pcb's. but then i figured out its just because the big drill press cant hold some of the tiny drill bits, like 1mm is way to small for the big drill press.
Oct 25, 2008. 10:00 AMnikremt says:
What is the diameter of the main part of the Micro die-grinder? That is, the red part of the die grinder in the picture from the link above. I want to know so that I can see if it will fit securely in a drill stand attachment that I already have.
Jun 13, 2007. 3:26 PMjoshcube says:
Instead of welding up a metal tube frame, you could build it out of 1" plywood cut with a jig saw or scroll saw. Bolting multiple thicknesses together would give added strength... not that you need a lot of strength to drill out PCB's. Just cruise the scrap bin at your local Home Depot periodically. I get 2 foot by 4 foot pieces of different thicknesses there all the time for 50 cents or a dollar.
Jun 14, 2007. 1:43 PMSmartbomb says:
My first thought was "Hello, 80-20!" You can build the frame from their super-light, super-strong materials without any welding. For anyone not familiar with them, go to www.8020.net - they call themselves "The Home of the Industrial Erector Set". Aluminum frame T-slot pieces. Extremely lightweight, extremely strong, and VERY well-made (i.e. everything you expect to be 90 degrees is exactly 90 degrees). Their website has all the information you need. Their solutions aren't rock-bottom in price, but as I get older I take more pride in my work, place a value on convenience, and I place a (small) value on asthetics too. Functionality first, but if it can look professional too, so much the better. If I end up doing this anytime soon (with 80-20), I'll post here with as much detail on kit pieces and assembly instructions as possible. Right now I'm getting killed at work so it might be a while... P.S. I have absolutely no affiliation with 80-20 at all, other than as a satisfied customer.
Jun 17, 2007. 7:58 PMSacTownSue says:
Cool Stuff Bomb. Surely cost more than stuff lying around the shop. But then I don't have any of that stuff lying around the shop. I did buy a gizmo to hold my power drill for a press ?$20? at Orchard Suppply Hardware. Not the precision and ease of use as a real drill press tho. To pay to buy all those pieces and pay someone to weld not so cheap. I'm looking for a way to build a bike trailer and don't want the hassle of trying to cut and weld the pieces for my design. Do you think 80/20 would hold together well enough for a bike trailer? Lots of bouncing around and 30-50 lbs of load. It looks like it would be good for prototyping stuff. Not as cheap as pvc pipe, but stronger. I was thinking about using the slotted bar type ?steel? stuff at the hardware store. You're the Bomb, Smartie.
Jun 18, 2007. 12:43 PMSmartbomb says:
Hey STS,
If I had welding equipment & some scrap iron, I'd probably weld the frame like in the instructable (which is a great one, I should have mentioned that in my first post). But I don't have welding equipment & I'm not good at searching out that kind of help, so 80-20 is the path of least resistance for me. I got addicted to the 80-20 T-slot stuff (not the HT) at my previous employer, and since then I've never looked back.
I work really close to an OSH, I should shoot over there & see what they have. Tomorrow I'll be in the vicinity of a Harbor Freight so I figured I'd pop in & spend some money. I haven't had the best luck with their stuff holding up but it's so inexpensive, I know that going in... :-\
Anyway, I'm an EE and not an ME, so all those courses that taught things like load shear and tensile strength & static & dynamic loading are long forgotten ( :-( ), but I know that the 80-20 materials are incredibly strong and used in a LOT of industrial applications. The reason I mention shearing etc... is that (as an avid mtn biker myself) I know that the dynamic environment of a loaded bike rack going over bumps, potholes, rutted dirt roads, etc. is different than a static load of say 1 ton on a cart.
My only concern would be the joining points during heavy transient loads/bumps. The extruded aluminum material is extremely strong & rigid, the question would be if the connectors are strong enough & can be tightened enough to ensure nothing would come apart during travel. Funny enough, I have a Bones 3-bike rack that I bought about 10 years ago, before I became aware of 80-20. Were I to need a new rack today, I might consider a similar project.
Anyway, I want to mention that the support folks at 80-20 are EXTREMELY knowledgeable & helpful & don't turn their noses up at you if you aren't BigCo. They (in my experience) treat all (potential and current) customers well. So my point is that if I were in your shoes, I'd call them up & mention what you want to do, and see what they can do to help you. I've never done a CAD design, all of my needs have been simple and I order simples pieces that come together at right angles.
The nice thing about the extruded aluminum, in addition to the light weight & cool aesthetic (IMHO), is that is doesn't rust.... kinda nice for an application like a bike rack.
Anyway, here a couple of links that *might* be of additional assistance:
The 802- Deflection
Calculator]
and
The 80-20 Design Resource Center
Sorry, I kinda feel like I punted on this, if I was a stronger designer I'd take a shot at your bike rack myself.
One other thing (then I'll stop the rambling) is there are a couple other places, at least, that offer strong lightweight aluminum construction pieces. I don't have firsthand experience with these 2, but they may have reference designs or assistance that get you going:
Faztek T-slotted aluminum solutions and TSLOTS extruded aluminum materials
I have a feeling that it's only a matter of time before some industrious Instructable fan will make the bike rack!
Sep 27, 2007. 1:35 PM_soapy_ says:
http://www.8020.net/Application-55.htm is a bike rack made from 8020 stuff, showcased on their own website. So it can be done!
Jun 14, 2007. 1:46 PMSmartbomb says:
Sorry - first post above, I didn't realize the link needed to be marked as such explicitly. (I mentioned above that I am getting older :-) )
80-20
Sep 30, 2007. 3:39 PM_soapy_ says:
Getting old is hard on you. But the other option is worse.
Jun 23, 2008. 2:40 PMDave Wilson says:
I got all the bits for about $30 and built it just as you said but the drill wont turn, am I missing something?
Jul 24, 2008. 8:43 AMthreepointone says:
You do have a compressor, right? =) Check if the compressor has enough pressure; the drill really doesn't work unless it's close to 110 psi (or whatever it was rated, check the harbor freight site).
Jul 20, 2008. 5:53 PMJohn Smith says:
cool and i have to say, that is some nice welds....TIG? MIG?
Apr 25, 2008. 8:10 PMshortman says:
Sears has a drill press for an electric drill and also a drill guide for one. This is the only way i could (BUILD) one.
Dec 29, 2007. 4:53 AMmrx23dot says:
I've bought the same drill, it has a very precise shaft. How much pressure I need, to drive at full speed? Is this 12V tire compressor enough for the job? Maximum Pressure: 300 PSI (?fake?) Or I need a bigger one like this: Max pressure(BAR/PSI): 8/115 Tank(L/GAL): 50/13.2 Power(KW/HP): 2.2/3.0
Jul 23, 2007. 7:05 AMmandy_modded says:
a cheap laser pointer would be nice to help align the pcb under the drill. great idea
Sep 27, 2007. 1:38 PM_soapy_ says:
Go for two, so you can put one either side, allowing you to compensate for the change in position of the spot when you change the work height. Have them cross at the exact point the drill hits, and you will always be that bit better and more exact than those without a parallax compensation system built into their laser guidance system. :-)
1-40 of 74next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:lancandy
