3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
$30 High-Speed PCB Drill Press
Step 4Mount the Deck, Slide, and Drill
Almost done, now we just need to mount the deck, slide, drill, and return springs to the frame.
We started by cutting the Deck out of some MDF we had around the shop. We cut a notch out of it to fit around the back of the frame. We mounted the drill to the drill-mount/slide with some zip-ties that we had around the shop, and then attached the slide to the small piece of angle-iron that was welded to the frame.
We drilled and tapped a couple of holes near the middle of the upper arm and also in the drill mount and ran the springs between them. This provided the auto-return for the drill.
We also tapped and drilled to holes into the base of the frame to attach the deck to. The screws in the deck are counter-sunk (see finished pictures on next step) so that the PCB's can slide around the top of the deck easily.
End-caps were installed to keep everything looking neat.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:lancandy
