3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
$30 High-Speed PCB Drill Press
Step 5Finishing Thoughts
Finishing Thoughts
We ended up attaching a spring to the slide and the back of the upper arm. We did this to remove any excess slack in the linear rail that might appear over time.
The only changes we may make is to add a handle to lower the drill. Currently you simply press down on the top of the drill which works great for now.
Our holes came out perfect, and there was absolutely NO noticeable wobble or tilt in the drill. Just straight, clean holes every time.
11 comments
Jun 19, 2007. 8:52 AMtechnopenguin says:
Also you could add a potentiometer to adjust the speed, and have an LCD or digit display to show the RPM, with the help of a small circuit or a microcontroller.
Oct 4, 2009. 1:34 PMadnimo says:
unless it's a humongous pot you won't be able to do that, you'll need PWM to drive the speed of the motor.
Oct 3, 2009. 4:09 PMthowardtf1 says:
I buy all my carbide bits with .125 shank to drill FR4 pcb material. I use 'Drill Bit City' ( www.store.yahoo.com/drillcity ). They seem to be priced ok, but have availability of all bits I need. (#67 (.0320) 10 for $15.00 at my last order.
May 19, 2008. 7:24 AMF7 says:
Can you recommend a source for miniature drill bits with an 1/8 shaft, suitable for drilling PCBs? Fiberglas will dull a drill pretty fast...
Sep 5, 2009. 10:59 PMBlackice504 says:
this cost a lot more then normal drill bits but get Titainium drill set i managed to find a good one from the local $2.00 asian shop and it was $7.00aud and they must be real the deal the brand name is duramax yes to the Russians this will be a funny brand name.
Sep 5, 2009. 10:34 PMBlackice504 says:
very nice work looks like something you got off the shelf thank you so much for idea's. PS i love my air tools over electrical tools.
Jul 23, 2007. 7:05 AMmandy_modded says:
a cheap laser pointer would be nice to help align the pcb under the drill. great idea
Sep 27, 2007. 1:38 PM_soapy_ says:
Go for two, so you can put one either side, allowing you to compensate for the change in position of the spot when you change the work height. Have them cross at the exact point the drill hits, and you will always be that bit better and more exact than those without a parallax compensation system built into their laser guidance system. :-)
Jun 19, 2007. 8:51 AMtechnopenguin says:
This is a cool idea and I really want to try it! Can you use this drill press to drill other things as well?
Jun 19, 2007. 3:57 PMtechnopenguin says:
Just out of curiosity, where did you buy it, and what's the part number?
Jun 13, 2007. 12:59 PMpoprivet says:
Lovely! I need a PCB drilling rig and might weld one up this weekend with your plans. Years back we made a somehwat similar rig with the drill mounted under the table and a BB-gun 2X crosshair sight on top. You put the PCB on the table, lined the hole position up under the crosshairs, held it down with your hands and pushed the lever to bring the drill bit up from underneath. The lever was rigged to a treadle-like foot lever so you had both hands free. It was quite disconcerting the first few times to see the drill bit coming at you through the gunsight! But it was really fast to put a lot of holes in the board accurately. Great instructable with excellent photos and descriptions, well done!
Jun 12, 2007. 11:04 PMnanonano58 says:
great idea !
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:lancandy
