3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
[A cheaper way to] Play Videos from your ipod on the BIG[er] SCREEN!!!
  • last photo ←
After I saw the sat instructable that basically told you to buy some stuff, I had to share this with the world, it uses a 3.5mm AV jack (standard if you own a Digital Video camera or DV camera) with a couple of the plugs reversed.
Materials::::
:: An iPod Video
:: An AV-RCA cable with a 3.5mm head
:: A TV
:: Half a Brain
Step 1Enable TV Output
Enable TV Output
Under the TV output settings, just make sure it says "Ask" Instead of "Off"
So when you select a video, the screen in the second picture will pop up.
75 comments
1-40 of 75next »
Jun 13, 2010. 4:24 PMmonkeys98 says:
where can you get one of these cables?
Mar 2, 2010. 7:26 PMRobot Lover says:
they are all in different holes... do you know something that i don't?!
Jan 27, 2010. 11:43 PMDiabloscope says:
Go to a car stereoshop,  they have a universal adapter ,for cars & CAN BE USED IN YOUR HOME , using the main connector on the bottom  ,   , it has  two wires for 12v+  connection  for Charging ,   has resistor built in .  if you are creative and  have a 12volt power adapter  ,you  dont have to worry about battery running Down !!
Oct 17, 2009. 5:50 PMhomemovies64 says:
 my 5th gen white 60gb ipod video wont work with this connection! Help please
Jun 29, 2009. 5:42 PMmiqt says:
...what firmware do you have to have on your ipod video, 5 or 5.5??? because i don't see any options of "tv" or anything like that.....i have audio, but not video...any help? 5th generation video ipod should work, right?
May 16, 2009. 12:12 PMabadfart says:
dose this work with zunes
Mar 19, 2009. 5:52 PMscienceboy63 says:
For any of you who are wondering, the new iPod Nano Chromatic, iPhone, or iPod Touch 1st or 2nd gen have a cable with a ID chip in them. This hack works only for the older models.
Apr 12, 2009. 1:14 PMSchooniedude says:
I got the sound on the tv, but not anything else. I have an ipod touch by the way.
Mar 3, 2009. 1:47 PMtbone121 says:
(removed by roller coaster)
Feb 9, 2009. 12:57 PMSigsaucer647 says:
someone needs to make one for the newer ipods that use the dock connector
Dec 26, 2008. 6:27 PMHerminator says:
For the ipods that don't work with this, get a cable with a built in chip.
DealExtreme
Dec 19, 2008. 5:51 AMz50j says:
does this work with the 2nd gen ipod touch?
Jul 27, 2008. 2:47 PMEmankcin says:
This doesn't work with the 3rd gen Nano. After I hook stuff up, and select the movie, and get to the step where it asks if I want to enable TV, and I select yes, it says to connect the TV out cable. I tried to trick the system by connecting the firewire connector, but it didn't buy it.
Dec 19, 2007. 7:20 AMvatkin says:
im almost sure this doesn't work with the ipod classic (6 gen ipods) and probably also the 3rd gen nanos
Jun 21, 2008. 12:00 PMgizmo_ult says:
it does just on your ipod it says video then click and go to settings that easy
Jun 7, 2008. 11:22 PMcraigdiesel666 says:
I can confirm this. I have the 80 gig Classic, and it needs the cable w/ a dock connector to send video out.
Jun 10, 2007. 4:13 PMcpotoso says:
(removed by author or community request)
Jun 11, 2007. 1:12 AMLasVegas says:
Jun 11, 2007. 12:33 PMcpotoso says:
Jun 11, 2007. 3:02 PMLasVegas says:
Jun 11, 2007. 3:13 PMcpotoso says:
Jun 11, 2007. 3:56 PMLasVegas says:
Jun 11, 2007. 6:23 PMcpotoso says:
Jun 11, 2007. 7:11 PMLasVegas says:
Jun 12, 2007. 1:43 PMcpotoso says:
Jun 12, 2007. 9:57 PMLasVegas says:
Jun 12, 2007. 11:56 PMcpotoso says:
Jun 13, 2007. 12:18 AMLasVegas says:
Jun 13, 2007. 8:57 AMcpotoso says:
OK, OK, lets stop this! We've taken over the thread for things that are really uncorrelated to it. Let's be friends :-) (should we delete all of this thread, since it is useless for the discussion at hand?)
Jan 21, 2008. 2:05 PMtechnodude92 says:
(removed by poster) ...lol
Feb 29, 2008. 5:29 AMNoBetterName says:
(removed by toaster)
May 31, 2008. 7:50 PMPSPerson says:
(removed by roaster)
Mar 23, 2008. 8:06 AMzpersichetti says:
wtf whys it say removed by toaster
Mar 23, 2008. 9:06 AMNoBetterName says:
Damn those toasters! They always delete my posts!
Jan 27, 2008. 5:53 PMMario2007 says:
Jun 13, 2007. 12:01 PMLasVegas says:
You'd be surprised how many service calls result in re-plugging in a power cord or peripheral.
1-40 of 75next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:tyeo098
Cool, another box!
