[Video] Large Scale Mold Making - Making the Negative "Tool"
[Video] Large Scale Mold Making - Making the Negative \"Tool\"
Making tools from the tools you already own... This almost sounds incestuous - almost.
This is the next phase of our fairing construction for the University of Central Florida's 2007 ASME Human Powered Vehicle. Here we will take a positive male mold and begin making a female negative "tool." We call it a tool because it can be used to make many duplicate copies. This tool is in fact a negative female mold.
To reiterate, this whole project is daunting. However, each individual step is not too scary and within the capability of most people handy with a few simple power tools. On the other hand, the price tag is scary. For this half alone, we used 5 gallons of polyester resin (circa $130).
21 minute Video - Lots of Time Lapse (now with captioned instructions)
Related
Video Large Scale Mold Making - Part 1
Video Mixing Polyester Resin
Video - Part Making
Step 1Making a Stand for Casting
Your mold will be different - but here's the idea.
We want to make 2 female tools - one for each side. To do this, we must split the mold lengthwise (to allow easy mold release). So, the stand needs to hold the entire plug on it's side to present a "waterline" right down it's center. Positioning is critical as we don't want to make a mold that curves around itself more than 90 degrees (making removal impossible).
This stand is constructed using recycled 2X6's as a base and with 2x6 risers. The risers support an MDF board that will contain the plug cut out (recycled is better - these boards are expensive for what they are). The risers are a little more than 1/2 the width of the whole plug (that is, 1/2 the height of the plug when it's on it's side).
To make the cutout - place the plug on top of the stand. Then, use a square positioned against the plug and MDF board - mark the base position with a pencil. Repeat this over the entire plug without moving the plug. Once this is done, drill a hole and cut out with a jig saw.
Once you have your hole -- sand the edges down with a block so it won't be too rough on your plug - this is important for bondo application later. Test fit. Shave down. Test Fit and repeat until you have a good fit. You don't have to be 100% accurate - but you want a waterline that is flush with your MDF surface.
To make a cheap sanding block - use a scrap bit of wood and glue on sand paper - ha! you saved $5 on a sanding block that would likely just break after a few hours of use.
15 comments
Jun 3, 2007. 5:00 AMSquee says:
That looks dreadfully exciting... I'm kinda glad I dropped engineering so I'm allowed to do things the "wrong" way again :-D
May 17, 2007. 8:59 PMFerrite says:
Why do you have to make a negative mold? Can't you make the final parts form the positive mold that you started with and then attach them togeather. It seems like that would save a lot of money.
Mar 31, 2007. 3:40 AMwestfw says:
Do you let the thickened resin cure any before applying the unthickened resin (eg between step 8 and 9)? How about in between the layers of glass? Do you know how the PVA used as a release is different than the PVA used to make slime? (to make slime, I make a 4% solution in water, starting with solid PVA. This gives me a liquid like runny syrup, which is significantly thicker than the PVA solution I see at tap plastics (and it's clear rather than green.)) Is it a different MW of PVA, or additional additives in the release version, or ...
Apr 19, 2007. 5:00 AMdwrenne says:
Hi, The caption when adding the first lot of resin says to add, unthickened resin. Does that refer to not adding cabosil or does it mean don't add catalyst? I was thinking that maybe the first lot of resin is put on without catalyst to give ye time to get the first layer of glass on and that the rest of the resin would contribute it's catalyst. Doubtful, but I just wanted to make sure. Cheers Diarmuid
Apr 4, 2007. 1:09 PMT3h_Muffinator says:
Just a quesiton: When I interned over at a fire retardant development lab last summer, they were really worried about Cabosil and made me wear a really thick respirator mask. Just from what I've heard it's like breathing in razorblades, and it's pretty much lighter than air. Shouldn't you be wearing a mask??
Apr 4, 2007. 1:44 PMT3h_Muffinator says:
Alright, cool. Thanks for the info!
As for the safety precautions in that lab, they're pretty anal about safety. I suppose it was understandable for them to make me wear a mask.
Wait, MEK is worse than Cabosil?? Oh god.... I practically played with that stuff all day....
Oh well, now I know =P
Oh, and other than that, awesome Instructable =)
Mar 31, 2007. 10:51 AMcarlson says:
Great video, thanks for posting.
Mar 30, 2007. 10:18 PMLasVegas says:
This is an absolutely fascinating series, trebuchet! I'm anxiously looking forward to the next installment. I'm curious though... Which of the group is you? ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
313
Author:trebuchet03
I'm an Engineer in San Francisco. Mass producer. Former Intern. Rapid Prototyper. Sometimes, I post Instructables. My Favorite number: 42 By profession - I am an energy engineer. I count electrons p...
more »
