This is the next phase of our fairing construction for the University of Central Florida's 2007 ASME Human Powered Vehicle. Here we will take a positive male mold and begin making a female negative "tool." We call it a tool because it can be used to make many duplicate copies. This tool is in fact a negative female mold.
To reiterate, this whole project is daunting. However, each individual step is not too scary and within the capability of most people handy with a few simple power tools. On the other hand, the price tag is scary. For this half alone, we used 5 gallons of polyester resin (circa $130).
21 minute Video - Lots of Time Lapse (now with captioned instructions)
Related
Video Large Scale Mold Making - Part 1
Video Mixing Polyester Resin
Video - Part Making
Remove these ads by
Signing UpStep 1Making a Stand for Casting
We want to make 2 female tools - one for each side. To do this, we must split the mold lengthwise (to allow easy mold release). So, the stand needs to hold the entire plug on it's side to present a "waterline" right down it's center. Positioning is critical as we don't want to make a mold that curves around itself more than 90 degrees (making removal impossible).
This stand is constructed using recycled 2X6's as a base and with 2x6 risers. The risers support an MDF board that will contain the plug cut out (recycled is better - these boards are expensive for what they are). The risers are a little more than 1/2 the width of the whole plug (that is, 1/2 the height of the plug when it's on it's side).
To make the cutout - place the plug on top of the stand. Then, use a square positioned against the plug and MDF board - mark the base position with a pencil. Repeat this over the entire plug without moving the plug. Once this is done, drill a hole and cut out with a jig saw.
Once you have your hole -- sand the edges down with a block so it won't be too rough on your plug - this is important for bondo application later. Test fit. Shave down. Test Fit and repeat until you have a good fit. You don't have to be 100% accurate - but you want a waterline that is flush with your MDF surface.
To make a cheap sanding block - use a scrap bit of wood and glue on sand paper - ha! you saved $5 on a sanding block that would likely just break after a few hours of use.
![[Video] Large Scale Mold Making - Making the Negative \"Tool\"](/image/FS0BHXHFWWEZTBB5X2/Video-Large-Scale-Mold-Making-Making-the-Negat.jpg)
I asked that same question - no, no cure time. Once you mix the catalyst in the initial batch of resin, you're committed to finish completely - no stops.
Do you know how the PVA used as a release is different than the PVA used to make slime?
I don't know, but I'll ask today :)
On the subject of silicosis (this has been mentioned a few times now).... Silicosis requires the crystalline form of silica - like quartz. Fumed silica is colloidal - as such OSHA classifies fumed silica as nuisance dust and does not require personal filtration if the dust level is maintained at a low enough level - I think that is why there's a big health concern, someone hears silica and immediatly assumes silicosis.
Fumed silica isn't lighter than air -- but it is a particulate form of aerogel - a material with the lowest density compared to other solids. So it will float in the air for awhile, but eventually will settle out.
Now - comparing dust you find in your house to Cabosil.... Floating dust in your home is actually quite hazardous due to radioactive decay. Our soft tissues (that is, not our skin) don't block alpha particles very well.... If you ever get a chance to measure the radioactivity of household dust -- be prepared to be amazed :P Cabosil is completely inert (after all, it's pure silica sand :P) and doesn't have that effect.
Here is the MSDS
If your bossman required that you wear a respirator - it was probably a liability thing ;) OSHA requires that you either have taken measures to reduce the dust level through filtration or dilution (aka fans) OR that you wear an approved dust mask. If you were in a closed environment and a spill were to happen (say, someone put an air hose in the bucket), the dust level would quickly go above OSHA standards for use without a mask :P
I'm honestly not concerned for my own health with respect to this. The big hazard working with polyester resin the the MEKP and resultant styrene. So either have good ventilation or organic respirators :D
As for the safety precautions in that lab, they're pretty anal about safety. I suppose it was understandable for them to make me wear a mask.
Wait, MEK is worse than Cabosil?? Oh god.... I practically played with that stuff all day....
Oh well, now I know =P
