3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
[Video] Large Scale Mold Making - Making the Negative "Tool"
Step 6Isophthalic Tooling Resin - Cabosil - Mold Surface
Isophthalic Tooling resin is a fancy name for a type of polyester resin. It's a fun word to say too. It's catalyst is MEK-P - Methyl Ethyl Keytone Peroxide. MEKP More on this later in the step.
Cabosil is a thixotropic thickening agent. Cabosil, unlike micro balloons, becomes a homogeneous component of the resin. Micro balloons does not - but, they provide a lattice matrix (of spheres) which increases strength without increasing much weight (after all - it's mostly air).
Thixotropic means that if you leave the material alone, it will act as a gel. But, if you agitate it by brushing or mixing, it will act like a thinner fluid. This is how we can have a coating that stays were you put it and can be applied like a liquid.
Cabosil is fumed silica - but is not a glass. It is also VERY light. Most of the shipping weight of the 5 gallon bucket came from the weight of the bucket. I could put my hand in the stuff and it was as if nothing was around it. Another name for it is Aerosil - because fumed silica is very much like aerogel - in a particulate form. And if you didn't know before, aerogel has the lowest density of any solid known or made by man.
Lastly, Cabosil is a trade name - Cabosil is to fumed silica as Rollerblades are to inline skates. There is a brand name called "Cab-O-Sil" just like RollerBlade is a brand owned by Nike.
Our mold surface will be formed from a layer of resin that has been thickened with Cabosil and catalyzed by the MEK-P. Application in the next step.
A word about MEK-P
If you read the wiki, you already know it's related to Peroxyacetone (acetone peroxide). And yes, MEK-P will decompose rapidly (some would call it an explosion) if you give it enough of a shock. The MEK-P you buy for tooling is not 100% concentration - so it's quite hard to get it to decompose. That being said - respect these properties.
MEK-P IS A CORROSIVE - IT WILL EAT YOUR FLESH - IT MAY CAUSE OPTICAL NERVE DAMAGE - IT WILL ATTACK ORGANIC COMPOUNDS. This is the most dangerous compound of the process. It's powerful enough that we only need about 10cc per quart (1% of the resin). Epoxy based resins are safer in this regard, but MUCH more expensive. Additionally, this will eat most foams - so do not apply to bare foam plugs.
WEAR GLOVES AND PROTECT YOURSELF. Once you open the bottle, do not touch your face, ears, etc.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
323
Author:trebuchet03
I'm an Engineer in San Francisco. Mass producer. Former Intern. Rapid Prototyper. Sometimes, I post Instructables. My Favorite number: 42 By profession - I am an energy engineer. I count electrons p...
more »
