3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
[Video] Mixing Polyester Resin
Resin mixing is an important part of composite manufacturing. Here's how to do it safely and with an acceptable margin of accuracy.
WARNING - THESE INSTRUCTIONS INVOLVE THE USE OF METHYL ETHYL KEYTONE PEROXIDE (MEK-P), A CORROSIVE COMPOUND THAT IS MILDLY "EXPLOSIVE." GLOVES ARE A MUST AROUND THESE COMPOUNDS AS THEY WILL ATTACK ORGANIC LIFE FORMS - THAT MEANS YOU, YOU MEAT PERSON!
IF YOUR SKIN IS SPLASHED, IMMEDIATELY WASH WITH SOAP AND WATER - DO NO DILUTE WITH ACETONE. SEEK MEDICAL ATTENTION IF YOU HAVE A SEVERE REACTION OR DEVELOP A FEVER.
FIRE ADVISORY - POLYESTER RESIN IS FLAMMABLE. DO NOT SMOKE OR HAVE AN OPEN FLAME NEAR YOUR WORKING OR STORAGE AREA. DO NOT LEAVE CATALYZED RESIN UNATTENDED WHEN IN SIGNIFICANT QUANTITIES AS THERE IS A POSSIBILITY OF SPONTANEOUS COMBUSTION. SHOULD YOU HAVE A FIRE EMERGENCY, SMOTHER THE FLAME.
The following video is long, but full of tips, tricks and advice for working with resin for layup.
Glossary
MEKP - Methyl Ethyl Keytone Peroxide - polyester resin catalyst (hardener)
PVA - Polyvinyl Alcohol (film mold release)
Cabosil - the white silica filler being mixed in (trade name - aka Aerosil)
Tool - negative mold used to make parts
Micro Balloons - air filler encapsulated in silica glass (creates a lattice matrix structure in resin)
Gelcoat - provides a high quality finish to composite tool surface
Composite - material made from two or more substances (in this case fiber glass and resin)
Mat - Reference to chopped fiberglass in a sheet form; tearable by hand with strands about 1.5" long
Exotherm - reference to the heat generated/required by the resin to cure
Pot - Catalyzed batch of resin
Pot Life - Working/usable life of pot. After this time, the chemical reactions between catalyst and resin "take off"
Step 1What is it?
What is it?
Polyester resin is a synthetic resin (that is, it starts off as a fluid and hardens). Polyester resin is one of the more common forms of resins - epoxy resin being another very common form. When it comes to the marine industry, polyester resin is the most common as it is more rigid than it's epoxy counterpart. Keep in mind, the trade off for it's higher stiffness is that it is more brittle.
In its viscous form, polyester resin is flammable and a skin irritant - something we expect from a styrene based fluid. Manufactures mix their own blend of cobalt and other conditioner additives to help the curing process - however, Methyl Ethyl Keytone Peroxide is used as a catalyst.
Polyester resin is very common in tooling - that is, making molds (typically negative molds) that will be used to make a product. A major reason for this is, again, it's rigidity.
Finally, polyester resins are compatible with any type of fiberglass, fibrous carbon, Kevlar and urethane type foams (NOT styrene type foams). While the resin itself is compatible, the catalyst may not be (especially with foams). A test sample is always recommended before tooling.
10 comments
Jan 12, 2010. 9:09 AMdawgz031 says:
can i replace hardener with some superglue??? and a catalyst?
i really cant find a hardener near my place......
Mar 20, 2012. 5:52 PMsnowluck2345 says:
lol no.
Apr 2, 2007. 6:01 PMhay_jumper says:
This is informative and I like that you added warnings about the materials. However, I'm a little alarmed that nothing was said about safety when working with Cabosil. This stuff is very light and gets into the air very easily. Then it gets into your lungs and will eventually kill you by way of silicosis. When I use this stuff I have a filtered vent hood for mixing and wear a particulate filter respirator throughout the process. All you have to do is open the can to see some of it float away. Even if you don't inhale it directly, it will settle as "dust" onto surfaces in your work space and when you clean or sweep will get reintroduced into the air. That ring around the bucket on the floor caused me to shiver. It's probably not a big deal if you only use this stuff very rarely, but if you are using Cabosil in large batches often, you will do well to protect yourself. Your lungs will thanks you.
May 6, 2008. 9:14 PMstasterisk says:
What do you make?
Oct 8, 2011. 4:34 AMmahmood memarnezhad says:
i can t see video
Oct 22, 2007. 4:22 PMpiper1234 says:
; ) tip my hat , many useful information, thanks a lot
Mar 30, 2007. 2:52 PMroyalestel says:
What? You haven't sold out to metacafe yet? :)
Mar 29, 2007. 9:10 PMMixMasterM says:
Very nice - thanks for taking the time to document and link the source/etc. I've always had uses for stuff like this, but just never found it easily.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
323
Author:trebuchet03
I'm an Engineer in San Francisco. Mass producer. Former Intern. Rapid Prototyper. Sometimes, I post Instructables. My Favorite number: 42 By profession - I am an energy engineer. I count electrons p...
more »
