Finding the Value of Π
1,036
8
8
Posted in HomeEducation
Introduction: Finding the Value of Π
About: HI i am currently studying in class 11...in love with computes and AI..
I will presnt a way to prove π = 3.14159 ............ using geometry and trigonometry................
it was originally made by David Coulson, Teacher / writer in maths and science
Pi Day Challenge 2016
Runner Up in the
Step 1: Basic Diagram
The circumference of the circle is bigger than the perimeter of the inner hexagon,and is smaller than the perimeter of the outer hexagon...........................
Step 2: Inner Hexagon
The perimeter of the inner hexagon is exactly 6 radii..................
The perimeter of the outer hexagon is harder to work out.................
Step 3: Outer Hexagon
The length of each side is 2R Tan 30 2R Tan 30
So, the perimeter of the outer hexagon is
6 x 2R Tan 30 = 12R Tan 30
Step 4: Value of Pi
The circle is sandwiched between the inner hexagon and the outer hexagon.
6R < Circumference < 12RTan 30
c= 2 π R
therefore,
3 < π < 3.4
Step 5: More Detailed
we can improve on the estimate by doubling the number of sides.
Step 6: More Detailed Vale of Π
12 sin15 < π < 12 tan15
therefore,
3.106 < π < 3.21
Step 7: FORMULA
In general, for an n-sided polygon inside the circle and another one outside of the circle,
n x Sin (180/n) < p < n x Tan (180/n)
As the number of sides increase,
the value of p is squeezed more tightly by the upper and lower limits.
Step 8: Final Value
SEE the chart above based on previous formula.........
the max and min valve of π is same when no.of sides = 6,114
and thus the value of π is 3.141593
BUT
When a calculator or spreadsheet generates the SIN or TAN of an angle, it is using a formula that depends on the value of pi.
Step 9: Solving Problem
You can use geometry to get the COS of 60 degrees.........that is 1/2 or 0.5 ....and then we can use the half angle formulas to generate all the SINs and TANs you need after that.
Step 10: Value Found to Be 3.14159
So starting from 60 degrees, we can calculate the Sin, Cos and Tan of increasingly small angles..............
from the image you can see the value of π to be
3.14159
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    8 Comments
    You are kidding, right? Pi is an irrational number that can not be represented exactly. It has an infinite number of decimal places. The value 3.1415926535 is only an approximation. The only reason you got 3.14159 is because of the precision of your arithmetic.
    I will take an infinite sided polygon to make a circle....which makes the value of pi irrational.....thats how simple it is to comprehened.......nice work bro
    He's using "..." to denote that it goes on. The proof is just for the first digits. And I think it's obvious that you need to go on to infinity to get a more accurate number.
    Thanks for that reply.........I couldn't have given such a good reply.....your instructables are awesome........
    ThomasK19 is right I meant that only I have not given the dots....... elsewhere but in the most significant place that is the title............but peabody1929 thanks for more precision..............
    Wow i got my first prize ......Thanks instructables........
    I like the "May I Have a Large Container of Coffee" trick :D Why didnt my math teacher tell me this
    I guess internet is the best school and instructable is the best teacher...........
