自制小冰箱 Make a Mini-refrigerator by Ourselves.
3,774
47
12
Published
Introduction: 自制小冰箱 Make a Mini-refrigerator by Ourselves.
炎热的夏季,空间较小的寝室容不下一台硕大的冰箱。这时,自己用废旧的CPU散热器做一台迷你冰箱会给我们在夏日的生活带来不少快乐。让它给我们的夏天降降温吧!
The hot summer is coming! However,there is no room for a huge refrigerator in our tiny dorm. Therefore, we use the discarded CPU radiator to create a mini-refrigerator to bring us some joy of the summer life.
Step 1: 打洞 Hole Drilling.
在泡沫箱的一侧做出一个和半导体制冷片形状大小一样的洞。
Drilling a hole on one part of the bubble chamber which fits in with the semiconductor cooler.
Step 2: 安装冷面散热片 Fixing the Cooled Sink.
在泡沫箱的内侧用四个螺丝将装有废旧CPU上散热片的支架固定在泡沫箱上,并在散热片与泡沫箱之间加一层泡沫板,起到密封隔热的作用。
Inside the bubble chamber, use four screws to fasten the discarded CPU radiator. Between the cooled sink and the bubble chamber, use a foam board to seal and insulate heat.
Step 3: 安装制冷片 Fixing the Cooler.
把制冷片安放在泡沫箱的的洞里,使其冷面与上一步安装的散热片接触。
Put the cooler in the hole and make the cold side to contact with cooled sink.
Step 4: 安装热面散热片 Fixing the Heat Sink.
在制冷片的热面表面均匀的涂满导热硅脂,然后把另一个散热片安装在制冷片上,使其与制冷片紧密接触。最后把散热片固定在泡沫箱上。
On the surface of the hot side of the cooled sink, evenly paint the heat-conducting silicone grease. Then fix another cooled sink with the cooler, and then fasten the cooled sink.
Step 5: 安装汽泡纸 Stick the Bubble Sheet.
在泡沫箱的内表面铺上一层大气泡塑料纸,用双面胶固定在泡沫箱上。
Stick the bubble sheet into the inside of the bubble chamber.
Step 6: 安装锡箔纸 Add the Tinfoil.
在汽泡纸上铺上一层锡箔纸,并且固定在汽泡纸上。
Add the tinfoil on the bubble sheet and fasten.
Step 7: 接线 Order the Electric Wires.
在泡沫箱的外表面贴上一层塑料纸,使得它更美观一些。然后把烦乱的电线进行整理,安装上开关。
Order the electric wires and mount a switch.
Step 8: 通电 Put Through Power Supply.
最终,接上电源。一台迷你冰箱就做成了。
Connect with a power supply. A mini-refrigerator is born!
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    12 Comments
    您好!谢谢您参与到绿色电子挑战赛!
    很荣幸的通知您,您的作品已经入围决赛!接下来评审团们将对每个入围作品进行评选,届时将公布最终获奖名单!
    如果您有任何问题,请给此ID发送私信,谢谢。
    再次祝贺并祝您好运!
    -Instructables Team
    您好,请问我需不需要把制作过程翻译成英文?如果翻译成英文现在还能上传吗?
    您好,不用了,您参加的是中文竞赛
