风动力小车(The Wind Powered Car)
1,280
7
8
Posted in Technology3D-Printing
Introduction: 风动力小车(The Wind Powered Car)
About: 老衰男
项目本身来源于目前环保主题,由于传统内燃机汽车污染严重,电动汽车必将成为主流,以环保为切入点,进行电动驱动方式的小车设计,电动方式最环保是太阳能,考虑到室内光线问题,最终驱动方式定为风动驱动,本项目的确定综合了多方面考虑,如外形设计,行驶性能等作出要求。
The project itself from the theme of environmental protection, the
traditional internal combustion engine automobile pollution, electric vehicles will become mainstream, with environment protection as the starting point, by car design of the electric drive, the most environmentally friendly electric mode is solar energy, considering the indoor light, eventually driving method for pneumatic drive, determination of the project integrated in many aspects consider, such as the shape design, driving performance and requirements.
综上所述,造型要引人注目,外形应具有独到之处,兼顾满足风动小车行驶要求,阻力小、重量轻等特点。于是跳出常规汽车外形结构的束缚。本着这些思路,无意中发现蝎子的图片,突然闪现出灵感,蝎子那种好斗、凶猛的特点正好体现出车子的冲劲,并且结构上容易实现,能够满足外形独到、轻量等构思特点。最终呈现的模型效果还是达到了最初的期望,无论造型、行驶性能都达到了满意效果。
To sum up, other to attract sb.'s attention, should have one's own knack in shape, meet the requirements of pneumatic car driving, little resistance, light weight etc.. He jumped out of the shackles of conventional car shape structure. Based on these ideas, the scorpion pictures found accidentally, had a sudden inspiration, features a scorpion that aggressive, fierce just reflect the car to drive, and the structure is easy to realize, can meet the unique shape, such as the idea of feature weight. The model results or final presentation to initial expectations, regardless of form, performance achieved satisfactory effect.
Step 1: 材料及设备准备(Materials and Equipment)
一、制作要点
I, main points of making
(1)实体设计软件建模
(1) modeling entity design software
(2)三维打印
(2) three dimensional printing
(3)零件调整打磨涂装
(3) part adjusting polishing coating
(4)零件整体装配调整
(4) the overall assembly and adjustment parts
(5)驱动系统,照明灯光系统安装调整
(5) driving system, lighting system installation and adjustment
设备工具及材料
Equipment, tools and materials
硬件:计算机、三维立体打印机
Hardware: computer, 3D printer
软件:实体设计软件、三维立体打印机控制软件
Software: entity design software, 3D printer control software
附件:电机、扇叶、电池盒、Led、电线等
Annex: motor, fan blades, a battery box, Led, wire etc.
工具及辅料:电烙铁、焊锡、助焊剂、裁刀、锉刀、砂纸、补土、自喷漆、速干胶
Tools and accessories: electric iron, solder, flux, cutter, file, sandpaper, putty, paint, quick drying glue
Step 2: 创意设计(Creative Design)
The project itself from the theme of environmental protection, the traditional internal combustion engine automobile pollution, electric vehicles will become mainstream, with environment protection as the starting point, by car design of the electric drive, the most environmentally friendly electric mode is solar energy, considering the indoor light, eventually driving method for pneumatic drive, determination of the project integrated in many aspects consider, such as the shape design, driving performance and requirements.
As a result of this work considered to meet certain requirements, such as the track width, height, length of rail profile, creative, rationality of structure, speed and so on, so the need for system optimization in the scope of the provisions of the constraint conditions of the system inside, so that the system reaches the optimal target.
本制作还加入了电子控制、产品设计、草图、三视图等内容。
This production has also joined the electronic control, product design, sketch, three view etc..
The structure function analysis
在结构上采用偷轻设计,满足强度的前提下兼顾减轻重量的考虑,保证行驶速度,车架结构采用大量镂空设计;增加聚风筒设计,保证风扇推力集中,提升行驶速度的效果;增加灯光设计,两个幽蓝色的前灯就是蝎子邪恶的双眼,红红的尾灯预示着剧毒无比的毒针,为小车增加无比的趣味;采用三轮设计,结构上满足蝎子造型的轮廓,实际是为车子行驶减少摩擦的设计;由于脱离传统汽车造型,风扇前减少了阻挡物的设计更利于风扇效率的提升;增加导向轮设计,前低后高(两个后导向轮为了避免破坏整体结构,特意增加定风翼),保证车辆在滑道内灵活行驶;在前导向轮支架做出蝎子钳子造型,在车头镂空蝎子图案突出主题。
In the structure of the stolen light design, meet the strength of the premise of both weight into account, ensure the running speed, the frame structure using a unique design; collecting duct design, ensure the fan thrust, lifting speed effect; increase the lighting design, two blue light it is evil eyes, red tail light indicates so toxic stings, increase the great taste for car; the round structure design, meet the scorpion other profile, the actual is for the car to reduce friction design; because of breaking away from traditional car styling, fan front decreases the barrier are more conducive to the fan efficiency; increase the guide wheel design, before the low high (two after the guide wheel to avoid the destruction of the whole structure, add wing), ensure the vehicle flexible driving in the chute; other to make scorpions pliers wheel bracket in leading, in the front hollow scorpion design to highlight the theme.
Through the above design, final both appearance and travel have achieved excellent results.
Step 3: 步骤三、 实施过程 (III,The Implementation Process)
III,The
implementation process
首先制作设计实现了风动小车创新的设计理念,采用仿生外形,模仿极具攻击性、凶猛好斗的蝎子作为设计蓝本,给人耳目一新的感觉;
Firstly, the design idea of designing pneumatic car innovation, use of bionic shape, imitate very offensive, aggressive scorpion as a design blueprint, give a person find everything fresh and new feeling;
(1)确定模型尺寸
(1)To determine the size of model
宽度不大于120mm,长度不大于180mm(参见图3)、
The width of not more than120mm,The length of not more than180mm(See The picture-3)
(2)Design sketch
(2)设计草图构思
According to the idea to draw the basic structure diagram(The picture-16 and The picture-17)
根据之前创意构思绘制基本结构图(图16及图17)
The picture-16 Axonometric drawings The picture-17 The
left optic sketch
(3)设计建模
(3)Design modeling
根据草图尺寸应用实体设计软件对车身和车轮等零件分别进行设计建模。
According to the sketch size application entity design software of the body and the wheels and other parts are designed modeling.
A本风动小车的车身、车头、中护板、后轮罩、定风翼零件根据其结构特点,建模方法主要采用拉伸、旋转、镜像、放样、曲面裁剪、抽壳等方式,效果图参见图18至图22。
A The pneumatic car body, the front, middle guard plate, rear wheel cover, the wing parts according to its structure feature, modeling method mainly adopts the stretching, rotation, mirror, lofting, surface trimming, shell etc., Effect diagram see The picture-18 to The picture-22。
B风动小车的车轮、滑轮、车灯、聚风筒结构都为回转类零件,宜采用旋转增料、拉伸等建模方法获得,效果图参见图23至图28.
B The wheel, pulley, lamp, poly pipe pneumatic car structure for rotary parts, should be obtained by rotation increase material, tensile modeling method,Effect diagram see The picture-23 to The picture-28.
C零件设计完成后采用三维球进行组合装配,并验证各个零件间是否有干涉及结构上的不足,进一步完善,效果图参见图29至图32。
C Parts after the design is completed using three-dimensional ball assembly, and verify that you have less interference and the structure of the parts, to further improve the, Effect diagram see The picture-29 to The picture-32。
D进行装配及结构修正后,根据加工工艺特点要求,完善零件的加工工艺性及细节,生成结构草图,参见图33
D Assembly and revised requirements according to the technical characteristics, processing, perfect and the detail process of parts, generating structure sketch,see The picture-33
Step 4: 步骤四:加工要求说明(IV. the Processing Requirements)
(1)打印
小车的所有零件均采用3D快速成型机打印,为了保证整体结构的强度,打印参数需要仔细设置,如层高、网格疏密等;因小车由多个零件组装而成,因此各零件的加工精度要求高,参数设置尤为重要。为防止零件重叠部分在打印中出现问题,应对小车各个零件拆散后再进行打印。
(1)Print
All parts are used to print car 3D rapid prototyping machine, in order to ensure the strength of the integral structure, the print parameters need to be carefully arranged, such as floors, mesh density; because the car by assembling a plurality of parts and machining accuracy, so the parts with high requirements, parameter setting is very important. In order to prevent parts overlap problems in print, to car parts after printing.
(2)装配
打印好的零件进行修整后,再进行试装配,试装配无问题后方可粘结,装配需保证各运动件运转灵活可靠。
(2)Assembly
The printed parts are trimmed, and then try to assemble, test assembly without the problem before bonding, the assembly to ensure the moving parts and flexible and reliable running.
(3)后期处理
后期处理时,注意原子灰(或补土)不要太厚,避免不必要的增重,打磨时不要太重,避免影响强度。涂装时注意通风防尘、防火。
(3)Post
processing
Post processing, attention (or putty putty) not too heavy, avoid unnecessary weight, grinding is not too heavy, avoid the impact strength. Pay attention to ventilation and dustproof, fireproof coating.
(4)电子器件及灯光安装
电子器件装配注意电极正负,包括电机转向和Led灯光。
(4)Electronic
devices and lighting installation
Electronic device assembly electrode positive and negative attention, including the steering motor and Led lights.
Step 5: 步骤五:制作过程(V. the Machining Process)
(1)三维打印
利用实体设计软件把设计文件转换成STL文件,导入3D打印机,正确设置打印参数,装填打印材质,调整设备到正确状态,进行打印。效果参见图34.
(1)3D
printing
The entity design software to design file into a STL file, import 3D printer, print parameters correctly, packing printing materials, equipment adjustment to the correct state, print. Effect diagram see The picture-34.
(2)修整装配
把打印完成后的零件小心剥离底板,去除支承材料,对精度较低部分进行修整,损坏不足部分进行粘接填补,按照装配图对零件进行装配。效果参见图35至图36.
(2)Trim assembly
To print the finished parts carefully peel bottom, removing the support material used for trimming precision, lower part, damage the insufficient portion adhesive filling, according to the assembly drawing of parts for assembly. Effect diagram see The picture-35 to The picture-36.
(3)涂装美化
确认试装配无误,即可进行涂装美化,表面美化效果最好的方法是采用丙酮熏蒸,但是由于安全、环保及健康原因不推荐此方法,老师掌握即可。本示例采用原子灰(补土)填补,砂纸打磨方法进行的表面处理,相比丙酮法耗时很长,效果也不错,打磨完成使用自喷漆完成涂装。注意:打磨和涂装环节注意个人防护及通风,建议室外操作。效果参见图37至图38.
(3)Coating.
Verification test assembly without error, can beautify the surface coating, beautify the best approach is using acetone fumigation, but because of safety, environmental protection and health reasons, do not recommend this approach, the teacher can grasp. This example uses the atomic ash (filling) fill, surface treatment sandpaper and grinding method, compared with acetone method is long, the effect is also good, the completion of the use of spray paint finish painting. Note: polishing and coating process pay attention to personal protection and ventilation, suggestions for outdoor operatio。Effect diagram see The picture-37 to The picture-38.
(4)附件及电子部件安装
在小车全部结构调试顺滑后,进行附件及电子部件安装,包括电机、开关、电池盒、电阻、LED等,在安装过程中注意电极正负,尤其LED不能接错电极,通电测试合格后,对线束进行整理、固定。效果参见图39至图42.
(4)Accessories
and electronic component mounting
In the debug car all structure sliding, and electronic component mounting of accessories, including motor, switch, a battery box, resistor, LED, pay attention to the positive and negative electrodes in the installation process, especially LED can not take the wrong electrode, energized after passing the test, to harness were collected, fixed. Effect diagram see The picture-39 to The picture-42.
Step 6: 步骤总结(Step Summary )
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    8 Comments
    创意很好,值得推荐!
