Introduction: ( E.A.P) Eliminator Assault Pistol
Get ready to meet your doom on the battle field, the brick wall in your path. You've met it's predecessors the TBAP and the TBOS. And you've seen the teaser. So now it's time to meet the ultimate Oodammo pistol, the Eliminator Assault Pistol.
The most innovative part is the on-the-go loading. All you have to do to load, is slide the orange connector up till it locks in place and push the bullets in. No more fussing with a guide rod in the mag, not even with a mag pusher. One of it's advantages over other oodammo guns is the ability to load the mag when it's still half full. You can also load all 17shots at once which only takes me about 5 seconds. Another good thing about the gun is that the true trigger, blocks the ram as far back as possible. Only 2 centimeters from the back, leaving 12 1/2 centimeters for the ram to gain speed.
It might not look best to some, but it functions great. The E.A.P has a range of about 50 feet, a 17 round mag, and the same good accuracy most Oodammo guns have.
Let's recap:
50 foot range
Same great accuracy
17 round quick-load mag
True trigger
Good handle
Sound like a good gun?? Well let's start building.
Let me know what you think it only takes a few seconds.
Also don't forget to
SUBSCRIBE
Killer~SafeCracker
Step 1: Step 1
First off I would like to say that my camera is not the best. So the pictures might be a tad fuzzy.
Picture 1: Build this thing.
Picture 2: Build this. It shouldn't be that hard.
Picture 3: Just build it.
Picture 5: Now connect the two part together.
Picture 6: Add the back on and your done.
Now that was as easy as pie.
Step 2: Step 2
Picture 1: Go ahead and build this.
Picture 2: Add the rods where shown.
Picture 3: Make these parts.
Picture 4: Add them to the side panel.
Picture 5: Make this.
Picture 6: Add it to the handle.
Picture 7: Make these parts for the trigger.
Picture 8: Add them to the side panel. Sorry for the picture being so bright.
Picture 9: Make this.
Picture 10: Add it to the panel.
Step 3: Step 3
Picture 1: Add the other side panel.
Now you're 1/2 done.
Step 4: Step 4
Okay here we go.
Picture 1: Build two of these.
Picture 2: Build these.
Picture 3: Add the third side panel.
Picture 4: Add the fourth side panel.
Picture 5: Add the mag like so.
Step 5: Step 5
Picture 1: Add that strip on both sides.
Picture 2: Add the wheels to the handle.
Picture 3: Push in the white rods as shown.
Onto the next step. -->
Step 6: Adding Rubberbands.
Picture 1: Insert blue rod.
Picture 2: Build ram.
Picture 3: Place band like shown. But if you use more then one make sure all but one are over the blue rod.
Picture 4: Add rubber band to the trigger.
Picture 5: Add rubber band to the orange connector like shown.
Step 7: Loading
e rodPicture 1: First off push the orange connector up until it locks in place.
Picture 2: Just push in 17 bullets.
Picture 3: Release the pusher.
That's one way to do it. Now I'll show you the faster way.
Picture 4: Make these things.
Picture 5: Add the Oodammo on the rod.
Picture 6: Pull up the pusher.
Picture 7: Snap the 17 bullets in and remove the rod
Step 8: YOU'RE DONE!!!!!
YOU'RE DONE!!!
Congratulations
If you have any questions feel free to ask.
Also don't forget to subscribe.
Killer~SafeCracker
196 Comments
if i cut a flex rod it is gonna work
I made a parts list. It is 100% accurate except for maybe 2 green rods.
Connectors:
Snowflake-------------------7
Blue 7 way------------------2
Yellow------------------------29
Green------------------------5
Red---------------------------20
Gray 2 way------------------5
Orange-----------------------14
Gray 1 way------------------14
Rods:
Black/Gray-------------------3
Yellow-------------------------2
Blue----------------------------7
White--------------------------28
Green-------------------------85
Red----------------------------1
Odds and Ends:
End of Rod(Step 2)--------1
Y connectors----------------14
Tan clip-----------------------5
Small black wheels-------6 (You don't have to use these they just make it feel nice)
Blue Clip---------------------2
Anything for the end of the ram, and, of course, rubber bands!
OMG thanks for the part list.
Y connectors---------------------14
My Y connectors------------------21
I can build it!!
Oh, and AWESOME gun by the way. I made your T.B.O.S. and IT is also AWESOME. By just lookin' at ye guns, I can tell you are a K'nex GOD. And your T.B.A.P. is also AWESOME. 5* for all (Including the T.B.A.R. and T.B.U.A.R.! Which were also AWESOME!)!
My trigger snaps.off Sometimes is it normal
Without seeing your build my best advice would be make sure there isn't too much pressure on the trigger.
ok my trigger is bent against the rod though should it be going with it?
Me gusta. . . . XD Looks awesome, and I'm planning on building it, as soon as I have enough Y-connectors. . . . fail, I know. . . . . . . . . Great job though!! :D
Me Gusta Mucho.
im gona make this 2!! it looks epic! 5*..AGAIN! i never gave u a rate under 5*.. ;) yw!
