-- IRON MAN Shared His Arc Reactor --
8,864
24
Posted
Introduction: -- IRON MAN Shared His Arc Reactor --
Hii guys !!
History
Tony Stark or IRON MAN , a movie character has some sort of reactor which keep him alive , its like free source electrical energy which allow the current in electromagnet to flow and stop the iron particles to move to his heart
let have it , NO not iron The Reactor mann !!
Wanna Learn Photoshop or Pixlr :
---Lets-Learn-Photoshop---
----Lets-Learn-PIXLR----
I got pics that r used and just collaborated then all together in  a single pic
Step 1: Collecting the Images to Be Used
Collect the images that u want to add in ur pic
Then open PhotoShop, pixlr ets
i collected these images to use
Step 2: Remove the Background If Required
Add the Image with person and duplicate
DUPLICATING is done to have a another copy of the image if we messed  up some where
Use Selection tools : WAND , POLYGON , QUICK etc tools
>> In my case i removed the white portion behind the image
TIP : You can also have another layer(Black or white depending on image)  added behind so that u can see if every unwanted area to be deleted.
Step 3: Getting Arc Reactor
i Added Arc Reactor in new tab of photoshop
again we need to separate  the arc reactor i use selection tool to separate it.
>> right click with any selection tool and use Refine edges after having a partial selection.
>> use the instruction  on images to process it by ur self
Step 4:
CTRL + V or paste it in the layers ,
You get Another NEW LAYER added of the reactor
>>as seen your reactor can be below the layers
    bring it to above layer by drag and drop
>>You can also make it smart object , right click on layer  and click on convert to smart object
    Smart object when transformed with shape , do not loose details
>>Select Arc Reactor and Place it right on Chest , Use CTRL + T or Edit--->Free Transform to transform the shape .
    Use SHIFT while u drag for transformation , it will not stretch image
>>when pasted on chest  remove the extra parts from Arc reactor
    Also used Burn tool to create darkness on the center potion on layer with person inside
>>Double click on layer to add Blending options
    >> use outer glow with color picked up from the arc reactor and make deatils as in images of blending options,
         it gives glow effect ,,so 90 % is done
Step 5: More Effects
Now use some logos and some other effects to improve the image
also add some gradient to background as in pic u see
Ist pic = Add this to layer and set Image mode to be "Darken" and place it in layer above background( create new )
2nd pic = Get Stark Industries logo out of the image and use it as we used the Arc Reactor
 See every pic for details :
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    I will refer back to this when I get some time! Thanks for sharing.
    Sunshiine
