$$ Super Cheap Inline Power Pack $$
Published
Introduction: $$ Super Cheap Inline Power Pack $$
About: Hello, You can call me Rex. I'm intrigued by electronics and always on the lookout for a cool project to make my Family smile. I just posted my first Instructable and I got the happy response from my da...
Hello Everyone!
I was working on a Project, in which I am almost done with, but I needed an Inline Power Pack. I looked around and I couldn't even locate one! The reason why I needed an Inline Power Pack was due to the internal specifications of the project that I was working on. I thought that I would just build one and in turn I came up with a way that everyone could build one and easily and inexpensively make it to have the voltage specifications of your project needs.
Well Guys and Girls, I hope you like this idea and can incorporate it into your project if you have a need for it too!
Step 1: Determine the Battery's Dimensions
  1. Before measuring the battery, be sure to apply electrical tape over the battery ends (+ & -) so you don't damage your battery or cause any unwanted actions to occur.
  2. Measure the length and width of the battery.
Step 2: Step 2: Select a Cylindrical (non-metallic) Tube That You Battery's Fit In.
I have a section of PVC Pipe left over from a old project which will work out just fine.
The inside dimensions of the PVC Pipe is 1 inch, which will work perfectly!
The C-Battery Length was 1.95 inches, so if I wanted to stack up (3) C-Batteries, we would multiply the length X 3. Which, when we add the batteries in Series would give me 4.5 Volts.
1.95 X 3 = 5.85 inches
Now, we need to add a little bit of room in the end caps for the Battery Terminals, 3 millimeters or 1/8" will do.
Step 3: Step 3: Cap the PVC and Add Terminals
During this step I needed to put a cap on one end of the PVC as well as put a spring in the bottom of it.
  1. I took the spring out of the Broken VCR Remote and bent the base wire outwards.
  2. Next, I took a box cutter and cut a small divot out of the edge of the PVC so the spring terminal could extend outwards.
  3. Then I cut (2) circles out of the VCR Case to make end caps for the PVC pipe.
  4. On the bottom end where the spring was going to be located I glued the spring and end cap into place.
  5. I drilled matching holes in the PVC for the positive end cap so I could easily remove it when I needed to replace the batteries.
  6. For the top end cap I cut a strip of the VCR Metal Sheeting that was located in the top of the VCR for the positive terminal. I bent the sheeting strip over my screw driver to achieve a slight curve.
  7. After scratching the cap and metal strip (to give a better adhesion) I glued it into place.
Step 4: Step 4: Test It!!
Connect it, Test it..... It's Alive!
  • Planter Challenge
    Planter Challenge
  • Woodworking Contest
    Woodworking Contest
  • Clocks Contest
    Clocks Contest
2 Comments
Very clever and very simple.
You don't even need a 3D printer!!! That's a bonus.
sorry for the outburst.
ahem... as I was going to say.....
I've been trying to workout how to make a splash proof case for my niMh and Ni-CAD battery packs and still stay compact and portable.
With your idea and some Sealant you've solved my problem.
Thank you.
That's Terrific!
During my search I found different size PVC Pipe fittings that were threaded too. You could always seal the threads with teflon tape, so you can take it off easily.
I'm happy that I could help you while doing my project!
I'm really starting to enjoy this Instructables website!
Thanks again for the positive comments and good luck!
