Introduction: -=!TRI-COLOR LED MOOD-LIGHT!=-
I like The Arduino a lot so I decided to make a Instructable for a L.E.D. MOOD-LIGHT that goes like this:
Green=on
Yellow=on
red=on
Green=off
Yellow=off
Red=off
And So on.
Step 1: -=Parts=-
You Will Need:
1x Yellow LED
1x Red Led
1x Green Led
?x Jumper Wires
3x Resistors
1x Arduino UNO
1x Solder-less Breadboard
20x Minutes
Step 2: -=Place the LEDS=-
Put The LEDS onto your breadboard as show in the picture.
Step 3: -=Connect the Negative Leads=-
Connect the negative leads of the LEDs to the negatve rail.
Step 4: -=Add the Resistors=-
Add the resistors to the positive leads on the LEDs.
Step 5: -=Connect GND to Negative Rail=-
Connect the GND pin on the Arduino to the negative rail on the Arduino.
Step 6: -=Connect Pin 13=-
Connect pin 13 on the Arduino to one end of the resistor connected to the green Led.
Step 7: -=Connect Pin 12=-
Connect pin 12 on the Arduino to the resistor connected to the yellow Led.
Step 8: -=Connect Pin 8=-
Connect pin 8 on the Arduino to the resistor connected to the red Led.
Step 9: -=Get Coding=-
This is the Code:
(Made By Me)
Just copy and paste into ARDUINO!
This Code Is Made By Building_Boy For Instructables.
It Will Cylcle Through A Red, Green, And Yellow L.E.D.
void setup() {
//Delcare pinModes
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
pinMode(8, OUTPUT);
void loop() {
digitalWrite(13, HIGH); //Turn On Green LED
delay(250); //Delay
digitalWrite(12, HIGH); //Turn On Yellow LED
delay(250); //Delay
digitalWrite(8,HIGH); //Turn On Red LED
delay(250); //Delay
digitalWrite(13,LOW); //Turn Off Green LED
delay(250); //Delay
digitalWrite(12,LOW); //Turn Off Yellow LED
delay(250); //Delay
digitalWrite(8,LOW); //Turn Off Red LED
delay(250); //Delay
Step 10: -=How to Change the Speed=-
To change the speed you need to open the code and change all of the (1000) into smaller numbers (For best effect use 250 on all the delays.
Step 11: -=!DONE!=-
Just Load the Code And You are done!
Now you have a cool mood-light!
Arduino Challenge
